楼主: x1a0jvn
[求助] 关于CREO 3.0模型显示的问题
发表于 2016-3-17 15:55 | 显示全部楼层
x1a0jvn 发表于 2016-3-17 15:45
虽然问题没解决,但还是非常感谢,按照您提供的方法,显卡电源为D0开启。配置选项已经修改了,没效果。显 ...
以下内容摘抄自 PTC Creo3.0 的配置说明
Graphics Information
For 3D-hardware acceleration, an OpenGL graphics card must be used that has been tested in a PTC-certified configuration. To ensure the compatibility of a graphics driver with Creo 3.0, a PTC certified or supported hardware configuration is recommended. Graphics cards that support at least OpenGL 4.0 are recommended for Creo 3.0.
 楼主| 发表于 2016-3-18 08:04 | 显示全部楼层
land908 发表于 2016-3-17 15:50
抗锯齿选项是在软件里面的,我觉得还是你的显卡不支持3.0的配置,3.0和2.0看起来没多大区别,其实在底层 ...
难道一定要换到2.0的版本么?实在不爱更换软件了
相互学习!相互帮助!共同进步!
GMT+8, 2025-8-18 22:41 , Processed in 0.127060 second(s), 24 queries .
