查看: 11966|回复: 4
[求助] keyshot如何设置成中文?keyshot到creo的接口说明里有些看不懂
发表于 2012-6-26 16:04 | 显示全部楼层 |阅读模式
keyshot不是多国语言版的嘛,安装好后,在哪设置成中文?
keyshot3_creo_plugin_1.4接口安装后,有会一个reade me.txt,里面第5到条到第7条看不懂。
1.  Open the Creo "Options" dialog from the File menu.
2.  In the "Configuration Editor" tab in the Options dialog, click
    "Add ..." to add a new entry to your configuration file which
    tells Creo to load the plugin.
3.  In the dialog which appears, enter "protkdat" as the option name.
4.  For the option value, click "Browse ..." and navigate to your
    KeyShot 3 Creo plugin installation.  This is typically located in
    "C:\Program Files\KeyShot 3\Plugins\Creo".
    Select the protk.dat file you see here and click "Open", then
    "OK".
    (This option is saved in a .pro configuration file, which is
    typically stored in your Creo working directory)
5.  Restart Creo. The KeyShot 3 plugin should new be loaded. To confirm
    this, run the Auxiliary Applications command. KeyShot 3 should
    appear in this list and can also be started and stopped in this
    dialog.
6.  To add the "Render now!" and "Settings" buttons to your ribbon,
    open Creo in either part or assembly mode.  Right click the ribbon
    and select "Customize the Ribbon".
7.  In the dialog that opens, the KeyShot 3 plugin commands can be found
    in the dropdown menu under TOOLKIT commands.  Simply add them to
    the ribbon under any existing group, or create a new one.  We
    recommend adding a "KeyShot 3" group under the "Render" tab.
    Remember, you'll have to add the commands for part and assembly
    mode separately.
109
绘图员
发表于 2012-6-26 16:22 | 显示全部楼层
我有做过教程
发表于 2012-7-7 17:10 | 显示全部楼层
楼主,在菜单 Help 下面有 注册许可证 选项,点选就可以设置成中文了。
发表于 2016-12-7 15:45 | 显示全部楼层
非常感谢,终于成中文了!
GMT+8, 2025-8-19 01:43 , Processed in 0.157105 second(s), 26 queries .
