查看: 274467|回复: 1599
[分享] KeyShot 3.2.32 官方简体中文多国语言版
绘图员
发表于 2012-5-24 09:11 | 显示全部楼层 |阅读模式
Keyshot 3.2.32 更新日志
Here is the final update for KeyShot 3.2. It contains a few more bug fixes.
The focus of this update is feature completion, UI cleanup, and stability. Here is a list of the most important improvements:
  • Improved material templates - support for parts and materials as template items, plus wild card support (*.*)
  • Instant loading of library - no longer do you have to sit and wait, even if you have thousands of materials in your library (same goes for environments, backplates, textures, renderings
  • Completely re-worked UNDO stack - UNDO pretty much everything.
  • Support for scale and transformations (remembered on all levels in the model)
  • Support for "unlimited" decimal places
  • Cylindrical texture mapping improvements
  • Use the arrow keys to move around in the scene tree, through the camera list etc.
  • Expand all / Collapse all options for scene tree
  • Sync of realtime and advanced render settings in render dialog (raybounces, shadow quality)
  • New camera "unsaved" state
  • Increase of maximum raybounces in realtime settings to 64
  • UI cleanup and performance improvements throughout the system
  • Improvements to SolidWorks importer (faster, more robust)
  • Improvements to ALIAS importer (Import by layer AND shader)
  • Support for Creo 2
  • Support for Autodesk ALIAS 2013
  • Support for Autodesk Maya 2013
  • Bug fixes
  • Added Spanish language support (UI only)
  • New materials
完整版安装包(推荐。已经安装3.2.32之前、3.0之后的,也可以直接覆盖安装,安装程序会自动升级原程序,并带新的库):
Windows 32位:
http://download.keyshot.com/keyshot_w32_3.2.32.exe
Windows 64位:
http://download.keyshot.com/keyshot_w64_3.2.32.exe
Mac OS X(这是苹果系统的,没破解):
http://download.keyshot.com/keyshot_mac64_3.2.32.pkg
升级包(仅适用于已经安装3.2.32之前、3.0之后的版本,仅含主程序,不含库,不推荐):
Windows 32位:
http://download.keyshot.com/keyshot_w32_3.2.32_update.exe
Windows 64位:
http://download.keyshot.com/keyshot_w64_3.2.32_update.exe
http://download.keyshot.com/keyshot_mac64_3.2.32_update.pkg
[ 本帖最后由 凡笔 于 2012-5-24 09:24 编辑 ]
参与人数 1威望 +3 金钱 +10 收起 理由
野火 + 3 + 10 感谢分享
绘图员
 楼主| 发表于 2012-5-24 09:12 | 显示全部楼层
破解补丁
1、安装 KeyShot 3
2、解压破解补丁,复制 keyshot3.exe 到你的安装目录 \bin,覆盖原文件
3、启动注册机 keyshot-windows-v2-keygen.exe,点击 Generate 生成许可证文件 keyshot3.lic
把许可证文件 keyshot3.lic 放到你的 KeyShot 3 库中,默认情况下它在 C:\users\[username]\Documents\KeyShot 3\
如果不知道在哪,可以打开桌面上的 KeyShot 3 Resources 快捷文件夹,这就是你的 KeyShot 3 库
4、启动 KeyShot 3,享受...
下载地址:
win 32位和win 64位:
版权问题,已删除
绘图员
 楼主| 发表于 2012-5-24 09:13 | 显示全部楼层
接口
下载地址:
http://www.keyshot.com/downloads/plugins/
接口会不定时更新,所以建议直接到官网下载
KeyShot 支持以下软件的接口
3ds Max 2012 或 2013
Creo 2.0 或之前的
Pro/ENGINEER Wildfire 3-5 / CREO/Elements Pro
Rhinoceros 4 或 5 32位
SolidWorks 2011 – 2012
SketchUp 7, 8
还支持直接导入以下格式:
  • ALIAS 2012 and prior
  • AutoCAD (DWG/DXF)
  • CATIA v5
  • Creo
  • Inventor 2012 and prior
  • NX 8 and prior
  • Pro/ENGINEER Wildfire 2 – 5
  • Rhinoceros 4 and prior
  • SketchUp 8 and prior
  • Solid Edge ST4 and prior
  • SolidWorks 2012 and prior
  • IGES
  • JT
  • Maya 2012 and 2011
  • STEP AP203/214
  • OBJ
  • Parasolid
  • FBX
  • 3DS
[ 本帖最后由 凡笔 于 2012-5-24 12:35 编辑 ]
发表于 2012-5-24 09:50 | 显示全部楼层
顶,不错
发表于 2012-5-24 10:02 | 显示全部楼层
这是什么东东呀
发表于 2012-5-24 10:14 | 显示全部楼层
下载试试看
宣传大使勋章
发表于 2012-5-24 10:42 | 显示全部楼层
这么快就更新了啊
发表于 2012-5-24 11:02 | 显示全部楼层
下来看看,没用过
发表于 2012-5-24 11:12 | 显示全部楼层
下来看看
发表于 2012-5-24 11:22 | 显示全部楼层
回复 2# 凡笔 的帖子
更新太快了
GMT+8, 2025-12-17 20:38 , Processed in 0.208220 second(s), 34 queries .
