查看: 3304|回复: 4
[求助] linux Pro/Engineer 3.0 m250弄了好多次了,就是不行啊
发表于 2012-5-10 21:29 | 显示全部楼层 |阅读模式
License request failed for feature PROE_DDiTy: -8:
Invalid (inconsistent) license key.
Displaying status for license file:/ptc_licfile.dat
License Server: none
                       License    In Use   Free   Version    Expire Date        SCN
                    PROE_DDiTy       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
              MECBASICUI_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
             MECBASICENG_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
              MECSTRUCUI_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
             MECSTRUCENG_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                MECMOTUI_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
               MECMOTENG_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
              MECTHERMUI_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
             MECTHERMENG_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
             MECINTERFCE_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
              MECTIREMOD_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                   MECUG_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                MECEQRUN_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                 2DGS-OA_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                 VERICUT_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
              WEBPUBLISH_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                 FLYTHRU_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
               FLYPLUGIN_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
               FLYVIEWER_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                 CONCEPT_12345       Uncounted       5.0         None       07071982 Locked to: 00-26-82-92-90-ED
              PROPACKENG_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
               PROPACKUI_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                    DS_MANAGER       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                DS_MANAGER-REP       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                    DS_SERVICE       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
               PROETRAIN_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
         MOCKUPCONVERTER_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                  MOCKUP_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
               MODELVIEW_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                   PVIEW_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
              RSDESIGNER_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                 TMSINDA_12345       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                     InterComm       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                    EDAconduit       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
                  EDAconnector       Uncounted      27.0         None       07071982 Locked to: 00-26-82-92-90-ED
WARNING: roadgo.com appears to have the loopback address 127.0.0.1 as IP address
This may imply that processes on roadgo.com may not be able to connect to non-local processes
[ 本帖最后由 roadgo 于 2012-5-10 21:35 编辑 ]
发表于 2012-5-11 20:53 | 显示全部楼层
这个系统用的人很少,不会弄呢
 楼主| 发表于 2012-5-14 20:15 | 显示全部楼层
再顶啊
发表于 2012-5-14 21:29 | 显示全部楼层
这个真的没法说了,到一些Linux专门论坛看看吧
发表于 2012-6-28 17:10 | 显示全部楼层
回复 楼主 roadgo 的帖子
到ubuntu论坛---办公、图像、机械电子设计里边  可以找到安装方法
GMT+8, 2025-10-29 01:02 , Processed in 0.147350 second(s), 31 queries .
