查看: 9268|回复: 11
[求助] 小弟做一個機箱結構分析時,出現下面的訊息,請大家幫忙看看
发表于 2008-7-11 11:06 | 显示全部楼层 |阅读模式
小弟做一個機箱結構分析時,出現下面的訊息,請大家幫忙看看,謝謝
"The design study terminated abnormally.
An error has occurred while requesting an additional
2.048 gigabytes of memory from the operating system.
To correct this problem, you may need to increase the amount
of swap space on your system.  You may also need to increase
the memory usage limits that are set for your system.
For large problems you can also try decreasing the
solram allocation setting.
At least 2.52134 gigabytes of memory are needed to run this design study.
Documentation for this issue can be found in the Technical
Support Knowledge base at:
    http://www.ptc.com/cs/tpi/128412.htm
For more information, you can search for the term "swap space"
in the Help Center. To access the Help Center Mechanica
topics, select #Help>#Help Center, set the functional area to
"Simulation" and then click on the "Structure and Thermal
Online Help" link.
這個問題要怎麼解決呢?時常看到這個訊息.
[ 本帖最后由 野火 于 2008-7-11 21:25 编辑 ]
热心助人勋章宣传大使勋章优秀会员勋章
发表于 2008-7-11 11:44 | 显示全部楼层
晕,又是全英文的,只能帮你顶个了
发表于 2008-7-11 12:04 | 显示全部楼层
按照英文翻译,是需要更大的内存支持
 楼主| 发表于 2008-7-11 13:16 | 显示全部楼层
我的虛擬記憶體最高已經調到8GB了,不會不夠吧??
不會是要加RAM吧?
還有沒有什麼辦法??
发表于 2008-7-11 21:24 | 显示全部楼层
磁盘空间还剩余多少?
发表于 2008-7-11 23:21 | 显示全部楼层
看不懂
 楼主| 发表于 2008-7-12 01:02 | 显示全部楼层
原帖由 野火 于 2008-7-11 21:24 发表
磁盘空间还剩余多少?
硬碟空間最少還有100GB
发表于 2008-7-12 11:29 | 显示全部楼层
I met the same issue.
My solution is:
sim_solver_memory_allocation 768 change to sim_solver_memory_allocation 512
512 is 0.5 times my machine RAM(1G).  It suggested by PTC:
Setting solram to 0.5 times machine RAM is usually the best compromise between reducing the amount of disk I/O and leaving enough machine RAM for disk caching and for other data. By limiting the solram allocation to half the machine RAM or less, you greatly increase your chances of achieving optimal performance. If there is too much demand on machine RAM and swap space, system performance can be severely degraded. In this situation, decreasing solver RAM can increase overall system performance.
发表于 2008-7-22 19:56 | 显示全部楼层
"设计学习终止反常地.
错误occurred当请求另外的
2.048记忆的十亿字节从操作系统.
到正确的这问题, 你可能需要到增加数量
的交换空间在你的系统.??你可能也需要到增加
记忆惯例界限那是设置为了你的系统.
为了大的问题你能也尝试递减
solram分配设置.
至少2.52134记忆的十亿字节是需要到运行这设计学习.
文件为了这出版能是发现在技术的
支持知识底部在:
? ? http://www.ptc.com/cs/tpi/128412.htm
为了更多的通知, 你能搜查学期"交换空间"
在帮助中心. To access the Help Center Mechanica
Online Help" link.
发表于 2008-8-23 22:03 | 显示全部楼层
原帖由 j032191 于 2008-7-12 01:02 发表
硬碟空間最少還有100GB
沒錯 把虛擬記憶體調高便可, 我剛有同一問題, 調高後重新開機已解決
再看是否setting 問題
GMT+8, 2025-12-2 16:52 , Processed in 0.158046 second(s), 30 queries .
