楼主: jinbiaoyes11
[已解决] creo安装问题无法获得 creo simulate 许可证
发表于 2012-2-16 18:17 | 显示全部楼层
可能是系统问题
发表于 2012-2-16 18:18 | 显示全部楼层
可能是系统问题
可能是系统问题
发表于 2012-6-28 08:52 | 显示全部楼层
回复 楼主 jinbiaoyes11 的帖子
求解答啊,同样的问题 。
发表于 2014-6-4 10:31 | 显示全部楼层
我的也是这样,求解决
发表于 2014-6-8 00:48 | 显示全部楼层
很好解决。看英文安装说明。
发表于 2014-6-8 00:55 | 显示全部楼层
Attention!
On Vista/Win7 be sure to run any patches by right mouse click > run as Administrator
If you didnt install the complete package, you will get "missing file" errors, do not serch the file, click Next
1. Open ptc_licfile.dat with any txt-editor and replace every occurance of 00-00-00-00-00-00 with you network card MAC-adress(   shown in the bottom left corner of the Creo setup)
2. Run Setup. On "License Identification" screen copy-past path to license file to string  "Source"
3.  Install Creo 2.0 F000 Parametric, Direct, Simulate, Layout, Distributed Services
4. For Creo 2.0 Parametric and Direct
copy "creo_2.0_f000_32bit_ssq.exe" to <Creo 2.0 installdir>\i486_nt\obj\ folder (by default C:\Program Files\PTC\Creo 2.0\Common Files\F000\i486_nt\obj\), run it and click Next >OK>Next >OK>..Finish >OK
5. For Creo 2.0 Simulate
copy "creo_2.0_simulate_f000_32bit_#1_ssq.exe" to <Creo 2.0 installdir>\mech\i486_nt\bin\ folder (by default  C:\Program Files\PTC\Creo 2.0\Common Files\F000\mech\i486_nt\bin\ ),  run it and click Next >OK>Next >OK>..Finish >OK
copy "creo_2.0_simulate_f000_32bit_#2_ssq.exe" to <Creo 2.0 installdir>\mech\i486_nt\ptc\ folder (by default  C:\Program Files\PTC\Creo 2.0\Common Files\F000\mech\i486_nt\ptc\ ),  run it and click Finish >OK
6. For Creo 2.0 Distributed Services
copy "creo_2.0_distributed_services_f000_32bit_ssq.exe" to <Creo 2.0 Distributed Services installdir>\i486_nt\obj\  folder (by default C:\Program Files\PTC\Creo 2.0\Creo Distributed Services Manager\i486_nt\obj\) , run it and click Next >OK>Next >OK>..Finish >OK
7. Enjoy
Cracked by Team SolidSQUAD (SSQ)
发表于 2014-6-8 08:08 | 显示全部楼层
求解决,我的也是这样的问题
发表于 2014-9-25 15:22 | 显示全部楼层
可以直接找檔案,所在位置
GMT+8, 2025-10-21 21:54 , Processed in 0.106877 second(s), 24 queries .
