eDrawings for Pro/ENGINEER
Download 32-bit version
eDrawings Professional for Pro/ENGINEER
http://edrawings.geometricglobal ... le.aspx?ProductID=5
Download 64-bit version
http://edrawings.geometricglobal ... e.aspx?productid=62
Publish, share and collaborate accurate representations of 2D and 3D product design data from Pro/ENGINEER files with eDrawings.
Register for free 15-day Evaluation
Supported Pro/ENGINEER versions
32 bit: Wildfire 5.0, 4.0, 3.0, 2.0, 1.0, 2001
64 bit: Pro/ENGINEER Wildfire 5.0, 4.0, 3.0, 2.0
Supported platforms
Windows® 7 / Vista / XP / 2000
eDrawings Professional for Pro/ENGINEER is the first email enabled collaboration tool designed to ease the sharing and interpretation of 2D & 3D product design data. It is a plug-in for Pro/ENGINEER that allows users to publish Pro/ENGINEER files as read only and ultra compact (upto 95% compression) eDrawings files for visualization, collaboration and design review.
Review enabled eDrawings files allow an unlimited number of recipients to easily query product designs and provide feedback. With eDrawings, the end recipients don’t need to buy any additional software for design review, markup, measurement and dynamic cross sectioning.
eDrawings also provides you with greater control over your design information by disabling measurement and STL exports as well as password protection.
Save eDrawings files as self extracting executables and zip files that contain the viewer as well as design data. With eDrawings executables, the end recipient does not need to download or install any additional software. Exporting to various image formats and STL is also available. eDrawings files can also be saved as HTML files for sharing on your websites and intranets.
Features & Benefits
Pro/ENGINEER Part/Assembly/Drawing support (*.prt, *.asm, *.dwg)
View, publish and share exact read-only representations of Pro/Engineer parts, assemblies and drawings for design review and collaboration.
Ultra Compact Files
Export your models to eDrawings to generate ultra compact (upto 95% compression) representations for sharing via email.
Add Markup Comments for Design Review and Collaboration
Add markup elements, such as geometric elements, clouds, text and dimensions to your comments using the markup tool.
Measurement
Measure part, assembly, and drawing geometry. Use in-built filters for easy selection of vertices, edges, faces and holes. This option can be disabled while publishing to eDrawings.
Dynamic Cross-Section
View dynamic cross sections of part and assembly files by creating a variety of cross section planes.
Password Protection & Data Security
Password protect your eDrawings. Disable measurement and STL export of eDrawings files to protect sensitive data.
Built-in Viewer
Save eDrawings as self contained executable (*.exe) and zip (*.zip) files, so that the end recipients do not need to download or install any other software for viewing eDrawings. View native SolidWorks files (*.sldprt, *.sldasm, *.slddrw) and DWG/DXF (*.dwg, *.dxf) files.
Save as EXE/ZIP with Built-in Viewer
eDrawings offers a complete, self-contained communication tool since no other viewing software is needed. eDrawings files can be saved as self extracting executables and zip files that contain the viewer as well as design data for sharing & collaboration.
Save as STL, HTML, BMP/JPEG/TIFF format
eDrawings can be exported by the eDrawings Viewer as HTML/STL/BMP/JPG/TIFF files.
Move, Show and Hide Components
Move, Show & Hide components to understand assembly structure more quickly
Insert Stamps
Insert your company logos and images as stamps in the eDrawings file.
Simplified representation, Multiple Drawing Sheets and Mass Properties support
Export Simplified representation, Family table instances, Multiple Drawign Sheets and Mass Properties to eDrawings.
3D data in Drawings
Visualize drawings more effectively by exporting 3D shaded data in drawing files.
eDrawings publishers are also available for CATIA, Unigraphics/NX, Autodesk Inventor, Solid Edge, SketchUp, CoCreate, KOMPAS & for STEP/IGES/STL formats.
[ 本帖最后由 fanyang95 于 2011-4-1 13:10 编辑 ] |
