悬赏5金钱未解决
allow_anatomic_features YES
axis_display NO
clip_always YES
datum_display YES
default_draw_scale 1
display_coordinate_sys NO
edge_display_quality VERY_HIGH
interface_quality 3
model_tree_start YES
pro_unit_length unit_mm
pro_unit_mass unit_gram
pro_unit_sys mmns
shade_surface_feat YES
smooth_lines YES
tri_quality 10
set_trail_single_step YES
trail_delay 0.1
datum_point_display NO
datum_point_symbol cross
allow_move_view_with_move YES
visible_message_lines 1
bell no
hlr_for_quilts no
tol_display no
spin_center_display yes
enable_tree_indep yes
enable_absolute_accuracy yes
dazix_default_placement_unit mm
menu_translation both
max_animation_time 0.3
text_height_factor 45
use_pre_wildfire_text_font yes
multiple_skeletons_allowed yes
scope_invalid_refs prohibit
default_object_invalid_refs prohibit
create_drawing_dims_only yes
highlight_new_dims yes
rename_drawings_with_object both
gtol_dim_placement under_value
mark_approximate_dims yes
parenthesize_ref_dim yes
enable_component_interfaces yes
enable_offset_fan_curve yes
make_proj_view_notes no
mass_property_calculate automatic
switch_dims_for_notes no
use_software_linefonts yes
use_8_plotter_pens yes
save_drawing_picture_file embed
provide_pick_message_always yes
highlight_layer_items no
tolerance_class medium
tolerance_standard iso
tol_mode nominal
allow_redo_intersections yes
fix_boundaries_on_import yes
intf_in_use_template_models yes
autoplace_single_comp yes
create_temp_interfaces yes
sketcher_auto_create_refs 2
show_selected_item_id yes
step_export_format ap214_is
info_output_format text
use_export_2d_dialog no
intf2d_out_enhanced_ents none
intf2d_out_pnt_ent yes
iges_out_ent_as_bspline true
intf2d_iges_out_hatch yes
iges_out_assembly_default_mode all_levels
iges_in_dwg_color yes
iges_out_dwg_color yes
intf2d_out_acad_mtext yes
intf2d_out_blanked_layers no
intf_out_blanked_entities no
intf_out_layer none
intf2d_out_acad_text_align as_is
intf2d_out_open_log_window no
dxf_out_sep_dim_w_breaks no
dxf_out_comments no
dwg_export_format 14
dxf_export_format 14
preferred_save_as_type step
preferred_save_as_type iges
preferred_save_as_type tiff
dim_inactive_components never
regen_failure_handling resolve_mode
prompt_on_exit no
prehighlight_tree no
autohide_external_sketch no
pen1_line_weight 2.5
pen2_line_weight 1
pen3_line_weight 1
pen4_line_weight 1
pen5_line_weight 1
pen6_line_weight 1
pen7_line_weight 1
pen8_line_weight 1
trail_dir E:\PtcTrail
!这一行是控制将路径文件放到E盘PtcETrail里面
search_path E:\PtcWork
!这一行是控制搜索路径,设置到启动目录
pro_font_dir C:\WINDOWS\Fonts
!这一行是让Proe软件可以使用系统字体,ProE软件自带的字体比较少,一般我们通过设置让ProE可以使用系统的字体
start_model_dir E:\PtcWork\templates
!这一行是控制从组件设计时,从模板开始创建零件
mdl_tree_cfg_file E:\PtcWork\tree.cfg
!这一行是控制模型树的配置文件路径,以后每次启动将自动加载此文件
system_colors_file $Pro_Directory\text\syscol.scl
!这一行是设置软件的系统颜色文件,指定全路径
tolerance_table_dir $Pro_Directory\tol_tables\iso
!这一行是设置ProE的公差表
pro_plot_config_dir $Pro_Directory\text\plot_config
!这一行是设置打印相关配置路径
format_setup_file $Pro_Directory\text\prodetail.dtl
!这一行是指定工程图的图框文件的配置文件
pro_symbol_dir $Pro_Directory\symbols
!这一行是设置符号库的位置,比如表面粗糙度,公司的标志等是以符号的方式插入,类似于CAD的图块
pro_note_dir $Pro_Directory\formats
!这一行是设置注释的位置,注释一般主要用于工程图的技术要求
template_designasm E:\PtcWork\templates\mmgs_asm_design.asm
!这一行是指定组合模板的路径
template_sheetmetalpart E:\PtcWork\templates\mmgs_part_sheetmetal.prt
!这一行是指定钣金模板的路径
template_solidpart E:\PtcWork\templates\mmgs_part_solid.prt
!这一行是指定普通零件模板的路径
template_mfgmold E:\PtcWork\templates\mmgs_mfg_mold.mfg
!这一行是指定模具模板的路径 |
