查看: 2498|回复: 1
[求助] proe安装后不能运行,有没有高手帮我一下啊?
tianus 该用户已被删除
发表于 2010-11-27 14:37 | 显示全部楼层 |阅读模式
发表于 2010-11-27 15:32 | 显示全部楼层
幸好我有 也装好了~~~~~~~
给你步骤
PTC Wildfire 5.0 x64
1. In the crack directory open the file called "ptc.dat" and 00-00-00-00-00-00 replace with your
   PTC host ID value then run "keygen.bat" which will create a license.dat.
2. Run setup and install Pro/e, Pro Mechanica and Distributed Services.
   Select Locked licensing and point to license.dat created at step #1.
3. Copy the "PTC_WF5_x64_Corrector.exe" to SAME LEVEL Directory as "installation directory"and run it.
GMT+8, 2025-11-7 06:54 , Processed in 0.106049 second(s), 31 queries .
