查看: 9963|回复: 0
[分享] PROE4.0的错误提示对照
发表于 2010-11-17 12:42 | 显示全部楼层 |阅读模式
这个是边学习边搜集来的
借花献佛
FLEXnet许可证错误代码错误代码说明
-1 Cannot find license file.
-2 Invalid license file syntax.
-3 No license server system for this feature.
-4 Licensed number of users already reached.
-5 No such feature exists.
-6 No TCP/IP port number in license file and FLEXnet Licensing service
does not exist. (pre-v6 only
-7 No socket connection to license server manager service.
-8 Invalid (inconsistent         license key or signature.
The license key/signature and data for the feature do not match. This
usually happens when a license file has been altered.
-9 Invalid host.
The hostid of this system does not match the hostid specified in the
license file.
-10 Feature has expired.
-11 Invalid date format in license file.
-12 Invalid returned data from license server system.
-13 No SERVER lines in license file.
-14 Cannot find SERVER host name in network database.
The lookup for the host name on the SERVER line in the license file
failed. This often happens when NIS or DNS or the hosts file is
incorrect. Workaround: Use IP address (e.g., 123.456.789.123         instead
of host name.
-15 Cannot connect to license server system.
The server (lmgrd         has not been started yet, or the wrong port@host
or license file is being used, or the TCP/IP port or host name in the
license file has been changed.
-16 Cannot read data from license server system.
-17 Cannot write data to license server system.
-18 License server system does not support this feature.
-19 Error in select system call.
-21 License file does not support this version.
-22 Feature checkin failure detected at license server system.
-23 License server system temporarily busy (new server connecting        .
-24 Users are queued for this feature.
-25 License server system does not support this version of this feature.
-26 Request for more licenses than this feature supports.
-29 Cannot find ethernet device.
-30 Cannot read license file.
-31 Feature start date is in the future.
-32 No such attribute.
-33 Bad encryption handshake with vendor daemon.
-34 Clock difference too large between client and license server system.
-35 In the queue for this feature.
-36 Feature database corrupted in vendor daemon.
-37 Duplicate selection mismatch for this feature. Obsolete with v8.0+
vendor daemon.
-38 User/host on EXCLUDE list for feature.
-39 User/host not on INCLUDE list for feature.
-40 Cannot allocate dynamic memory.
-41 Feature was never checked out.
-42 Invalid parameter.
-47 Clock setting check not available in vendor daemon.
-52 Vendor daemon did not respond within timeout interval.
-53 Checkout request rejected by vendor-defined checkout filter.
-54 No FEATURESET line in license file.
-55 Incorrect FEATURESET line in license file.
-56 Cannot compute FEATURESET data from license file.
-571 socket(         call failed.
-59 Message checksum failure.
-60 License server system message checksum failure.
-61 Cannot read license file data from license server system.
-62 Network software (TCP/IP         not available.
-63 You are not a license administrator.
-64 lmremove request before the minimum lmremove interval.
-67 No licenses available to borrow.
-68 License BORROW support not enabled.
-69 FLOAT_OK can’t run standalone on license server system.
-71 Invalid TZ environment variable.
-73 Local checkout filter rejected request.
-74 Attempt to read beyond end of license file path.
-751 SYS$SETIMR call failed (VMS        .
-76 Internal FLEXnet Licensing error—please report to Macrovision
Corporation.
-77 Bad version number must be floating-point number with no letters.
-82 Invalid PACKAGE line in license file.
-83 FLEXnet Licensing version of client newer than server.
-84 USER_BASED license has no specified users - see license server
system log.
-85 License server system doesn’t support this request.
-87 Checkout exceeds MAX specified in options file.
-88 System clock has been set back.
-89 This platform not authorized by license.
-90 Future license file format or misspelling in license file.
The file was issued for a later version of FLEXnet Licensing than this
program understands.
-91 Encryption seeds are non-unique.
-92 Feature removed during lmreread, or wrong SERVER line hostid.
-93 This feature is available in a different license pool.
This is a warning condition. The server has pooled one or more
INCREMENT lines into a single pool, and the request was made on an
INCREMENT line that has been pooled.
-94 Attempt to generate license with incompatible attributes.
-95 Network connect to THIS_HOST failed.
Change this_host on the SERVER line in the license file to the
actual host name.
-96 License server machine is down or not responding.
See the system administrator about starting the server, or make sure that
you’re referring to the right host (see LM_LICENSE_FILE environment
variable        .
-97 The desired vendor daemon is down.
1         Check the lmgrd log file, or 2         Try lmreread.
-98 This FEATURE line can’t be converted to decimal format.
-99 The decimal format license is typed incorrectly.
-100 Cannot remove a linger license.
-101 All licenses are reserved for others.
The system administrator has reserved all the licenses for others.
Reservations are made in the options file. The server must be restarted
for options file changes to take effect.
-102 A FLEXid borrow error occurred.
-103 Terminal Server remote client not allowed.
-104 Cannot borrow that long.
-106 License server system out of network connections.
The vendor daemon can't handle any more users. See the debug log for
further information.
-110 Cannot read dongle: check dongle or driver.
Either the dongle is unattached, or the necessary software driver for this
dongle type is not installed.
-112 Missing dongle driver.
In order to read the FLEXid hostid, the correct driver must be installed.
These drivers are available from your software vendor.
-114 SIGN= keyword required, but missing from license certificate.
You need to obtain a SIGN= version of this license from your vendor.
-115 Error in Public Key package.
-116 TRL not supported for this platform.
-117 BORROW failed.
-118 BORROW period expired.
-119 lmdown and lmreread must be run on license server machine.
-120 Cannot lmdown the server when licenses are borrowed.
-121 FLOAT_OK requires exactly one FLEXid hostid.
-122 Unable to delete local borrow info.
-123 Returning a borrowed license early is not supported.
Contact the vendor for further details.
-124 Error returning borrowed license.
-125 A PACKAGE component must be specified.
-126 Composite hostid not initialized.
-127 A item needed for the composite hostid is missing or invalid.
-128 Error, borrowed license doesn't match any known server license.
-135 Error enabling the event log.
-136 Event logging is disabled.
-137 Error writing to the event log.
-139 Communications timeout.
-140 Bad message command.
-141 Error writing to socket. Peer has closed socket.
-142 Error, cannot generate version specific license tied to a single hostid,
which is composite.
-143 Version-specific signatures are not supported for uncounted licenses.
-144 License template contains redundant signature specifiers.
-145 Bad V71_LK signature.
-146 Bad V71_SIGN signature.
-147 Bad V80_LK signature.
-148 Bad V80_SIGN signature.
-149 Bad V81_LK signature.
-150 Bad V81_SIGN signature.
-151 Bad V81_SIGN2 signature.
-152 Bad V84_LK signature.
-153 Bad V84_SIGN signature.
-154 Bad V84_SIGN2 signature.
-155 License key required but missing from the license certificate. The
application requires a license key in the license certificate. You need to
obtain a license key version of this certificate from your vendor.
-156 Invalid signature specified with the AUTH= keyword.
-500 Invalid server port number.
-501 Invalid value in license where an integer was expected.
-502 Invalid value supplied for count.
-503 Invalid hostid supplied in license.
-504 Invalid hostid type supplied.
-505 Bad feature line syntax.
-506 Internal FLEXnet Licensing error.
-507 Bad date format in license file.
-508 Bad SERVER line.
-509 Bad license string.
-510 Server's feature doesn't authenticate on client side.
-511 No license checked out.
-512 License already checked out.
-513 Error list returned.
-514 No certicom module available.
-515 Wrong or incomplete certicom module.
-516 SIGN or SIGN2 required in license certificate.
-517 Feature object has no license sources.
-518 An Identical license is already checked out on this license source.
-519 This license has an asynchronously-queued checkout pending.
-521 Library for native hostid couldn't be loaded
-522 Already connected to another vendor daemon.
-523 No such user, host, or display.
-524 Shutdown of license server system failed.
-525 Shutdown failed — already connected to license server system.
-526 Invalid license source string.
-527 Log file switch error.
中文的
-1找不到许可证文件。
-2无效的许可证文件的语法。
-3没有许可证服务器系统的这一功能。
-4许可的用户数量已经达到。
-5没有这种功能的存在。
-6没有TCP / IP端口号的FLEXnet许可证文件和授权服务
不存在。 (前6版只
-7否套接字连接到许可证服务器管理器服务。
-8无效(不许可密钥或签名。
许可密钥/签名和数据的功能不相符。这个
通常是因为许可证文件已被更改。
-9无效的主机。
在hostid这一制度不符合规定的hostid
许可证文件。
-10功能已过期。
-11无效的日期格式,许可证文件。
-12无效返回的数据由许可证服务器系统。
-13没有服务器线路许可证文件。
-14找不到服务器主机名称,网络数据库。
查找的主机名称的服务器产品线中的许可证文件
失败。这往往发生在院或DNS或主机文件
不正确的。解决方法:使用IP地址(例如,不是123.456.789.123
的主机名称。
-15无法连接到许可证服务器系统。
服务器( lmgrd还没有开始呢,还是错误的[电子邮件=港口@主机]港口@主机[ /电子邮件]
或许可文件正在使用,或TCP / IP端口或主机名称的
许可证文件已被更改。
-16无法读取数据的许可证服务器系统。
-17无法写入数据的许可证服务器系统。
-18许可证服务器系统不支持这一功能。
-19中的错误选择系统调用。
-21许可证文件不支持此版本。
-22特征签失败检测许可证服务器系统。
-23许可证服务器系统暂时繁忙的(新的服务器连接。
-24用户排队等待此功能。
-25许可证服务器系统不支持此版本的这一功能。
-26要求更多许可证超过此功能支持。
-29找不到以太网设备。
-30无法读取许可证文件。
-31特征开始日期是在将来。
-32无此类属性。
-33坏加密握手与供应商服务。
-34时钟之间的差异过大客户端和许可证服务器系统。
-35队列中的这个功能。
-36特征数据库损坏供应商服务。
-37重复选择错配的这一功能。过时v8.0 +
供应商服务。
-38用户/主机的排除清单功能。
-39用户/主机不包含清单的功能。
-40无法分配动态内存。
-41特征从未检查。
-42参数无效。
-47时钟设置检查供应商无法提供的服务。
-52供应商守护程序没有响应的超时间隔。
-53结帐要求拒绝供应商定义结帐过滤器。
-54无FEATURESET线许可证文件。
-55错误FEATURESET线许可证文件。
-56无法计算FEATURESET数据许可证文件。
-571插槽(调用失败。
-59信息校验失败。
-60许可证服务器系统的信息校验失败。
-61无法读取许可文件数据从许可证服务器系统。
-62网络软件( TCP / IP协议无法使用。
-63你不是许可管理员。
-64 lmremove之前要求的最低lmremove间隔。
-67无许可证提供给借款。
-68许可借款支持未启用。
-69 FLOAT_OK无法执行独立的许可证服务器系统。
-71无效雅轩环境变量。
-73地方结帐过滤拒绝请求。
-74尝试读取结束以后许可证文件路径。
-751 $ SETIMR系统调用失败(渔监系统。
-76内部FLEXnet授权错误,请报告Macrovision的
公司。
-77坏的版本号码必须是浮点数没有字母。
-82无效包装线的许可证文件。
-83 FLEXnet许可新版本的客户端比服务器。
-84 USER_BASED许可证没有指定的用户-见许可证服务器
系统日志。
-85许可证服务器系统不支持这一请求。
-87结帐超过最大配置文件中指定。
-88系统时钟已经回来。
-89这个平台的授权许可。
-90未来许可证文件格式或拼写错误的许可证文件。
该文件发出的版本比这个FLEXnet牌照
程序理解。
-91加密种子非独特。
-92特征删除在lmreread ,或错误的服务器产品线hostid 。
-93这一功能可在不同的许可证池。
这是一个警告的条件。服务器集中的一个或多个
增量线到一个单一的游泳池,并提出要求的
增量线已汇集。
-94能产生许可不兼容的属性。
-95网络连接到THIS_HOST失败。
涨跌this_host的服务器产品线中的许可证文件的
实际的主机名称。
-96许可证服务器计算机已关闭或没有回应。
见系统管理员关于启动服务器,或确认
您提到的权利东道国(见LM_LICENSE_FILE环境
变量。
-97理想的供应商守护下跌。
1检查lmgrd日志文件,或2尝试lmreread 。
-98此功能线不能转换为十进制格式。
-99许可证的十进制格式输入错误。
-100无法删除徘徊许可证。
-101的所有许可证都留给别人。
系统管理员保留所有许可他人。
保留是在选项文件。服务器必须重新启动
选项文件更改生效。
-102阿FLEXid借款发生错误。
-103终端服务器远程客户端不允许的。
-104无法借贷那么长的时间。
-106许可证服务器系统的网络连接。
供应商守护程序不能处理任何更多的用户。见调试日志
进一步的信息。
-110无法读取解密:检查集线器或驱动程序。
无论是独立的解密,或必要的软件驱动程序这一
解密类是没有安装。
-112失踪加密狗驱动程序。
为了阅读FLEXid hostid ,正确的驱动程序,必须安装。
这些驱动程序可从您的软件供应商。
-114标志=关键字需要,但缺少授权证书。
你需要获得一个迹象=版本的许可从您的供应商。
-115错误的公共密钥封装。
-116 TRL不支持这个平台。
-117借款失败。
-118借款期满。
-119 lmdown和lmreread必须在许可证服务器上运行的机器。
-120无法lmdown服务器许可证时,借来的。
-121 FLOAT_OK需要整整FLEXid hostid 。
-122无法删除本地借款信息。
-123返回借来许可证早期不支持。
的供应商联系的进一步细节。
-124错误返回借来许可证。
-125一个软件包的组成部分必须指定。
-126复合hostid未初始化。
-127 A项目所需要的复合hostid缺失或无效。
-128错误,借来的许可证不符合任何已知的服务器许可证。
-135错误使事件日志。
-136事件记录已被禁用。
-137错误书面向事件日志中。
-139通讯超时。
-140坏信息的命令。
-141错误书面插座。同行已关闭套接字。
-142错误,无法生成版本特定许可证被束缚在单一hostid ,
这是复合材料。
-143特定版本的签名不支持未许可证。
-144许可证模板包含多余的签字说明符。
-145错误V71_LK签字。
-146错误V71_SIGN签字。
-147错误V80_LK签字。
-148错误V80_SIGN签字。
-149错误V81_LK签字。
-150错误V81_SIGN签字。
-151错误V81_SIGN2签字。
-152错误V84_LK签字。
-153错误V84_SIGN签字。
-154错误V84_SIGN2签字。
-155许可证关键需要,但缺少授权证书。那个
应用程序需要许可证密钥的许可证证书。您需要
获得许可证密钥版本的此证书从您的供应商。
-156指定签字无效的AUTH =关键字。
-500无效的服务器端口号。
-501值无效许可下一个整数预期。
-502值无效供应数量。
-503无效hostid供应许可证。
-504无效hostid类型提供。
-505行语法错误的功能。
-506内部FLEXnet授权错误。
-507错误的日期格式的许可证文件。
-508错误的服务器产品线。
-509错误的许可证字符串。
-510 Server的功能不会验证客户端。
-511没有授权检查。
-512许可证已签出。
-513错误清单归还。
-514没有Certicom的模块提供。
-515错误或不完整的Certicom的模块。
-516签署或SIGN2需要许可证证书。
-517特征对象没有许可来源。
-518一个恒许可证已经选中了这个许可证的来源。
-519本授权有一个异步排队等候结帐。
-521图书馆本地hostid无法加载
-522已经连接到另一个供应商服务。
-523没有这样的用户,主机或显示器。
-524关闭许可证服务器系统的失败。
-525关机失败-已经连接到许可证服务器系统。
-526无效许可证源字符串。
-527日志文件切换错误。
参与人数 1金钱 +3 收起 理由
野火 + 3 感谢分享
GMT+8, 2025-11-7 09:27 , Processed in 0.136706 second(s), 24 queries .
