查看: 2931|回复: 3
[原创] 为什么到现行还有人安装不了破衣吗?
发表于 2010-11-13 21:25 | 显示全部楼层 |阅读模式
安装的方法。破衣一直到现在都没有变过,包括破解都是一样的为什么就是装不了 我就怀疑了
Installation Crack Method for PTC Pro/ENGINEER Wildfire
=========================Directory path can not be Chinese==================================
When Steps To Designated license server, Select the Locked license file (Server is not running)
1> Open license.dat then replace all string"00-00-00-00-00-00" with your PTC_HOST_ID(MAC address jusr Your netcard physical address) then save.
2> Install your pro/E &pro/M wildfire with above modified license file.Node Locked license method and No license server installaion needed.
2.Run patchs!
Aut proe-patch.exe under directory :
<Installed location>\proeWildfire 4.0\i486_nt\obj       then apply it.
But prom-patch1.exe under directory :
<Installed location>\proeWildfire 4.0\mech\i486_nt\bin      then apply it.
Cut prom-patch2.exe under directory :
<Installed location>\proeWildfire 4.0\mech\i486_nt\ptc      then apply it.
3.If you want install PTC Distributed Services,access PTC.Setup: other product->TC Distributed Services, use the modified license.dat at step one with node locked lic method. Then Put prods-patch.exe under directory :
<Installed location>\ptc_distributed_services\     then apply it.
发表于 2010-11-13 23:06 | 显示全部楼层
什么叫没变过?proe2001到proe5.0至少有3,4种安装不一样的,我简单举几个
1,proe2001是要先点lncptc修改网卡后生成license文件
2,proe2.0用记事本打开ptc.dat文件,把"host"    改成为自己电脑主机名和修改网卡ID后运 行"keygen.bat",获得license.dat文件.
3,proe3.0我用过一个版本是要先安装许可文件的,许可安装好后要到电脑控制面板---管理工具---服务-把许可先停用然后安装proe3.0主程序,最后再到服务里启用许可
4.proe4.0和5.0都差不多都是要复制到i486_nt----obj里去破解
 楼主| 发表于 2010-11-14 08:37 | 显示全部楼层
硬要这么说,给自己找借口,我无语了~~~~原理都一样~
发表于 2010-11-14 19:06 | 显示全部楼层
其实都很简单的
GMT+8, 2025-11-7 09:28 , Processed in 0.117805 second(s), 25 queries .
