查看: 3113|回复: 9
[求助] 【用5.0 M060的各位进来帮忙下】
clover718 该用户已被删除
发表于 2010-11-5 14:42 | 显示全部楼层 |阅读模式
发表于 2010-11-5 14:57 | 显示全部楼层
我的能装上啊
发表于 2010-11-5 15:00 | 显示全部楼层
有的在lic-gen里
clover718 该用户已被删除
 楼主| 发表于 2010-11-5 15:01 | 显示全部楼层
clover718 该用户已被删除
发表于 2010-11-5 16:27 | 显示全部楼层
破解文件在这里。(件附图)
发表于 2010-11-5 16:28 | 显示全部楼层
http://www.proewildfire.cn/thread-51427-1-1.html
具体的可以看看这样。
发表于 2010-11-5 20:56 | 显示全部楼层
看楼上贴的教程就可以
发表于 2010-11-6 18:02 | 显示全部楼层
和以前的安装都一样的
Installation Crack Method for PTC Pro/ENGINEER Wildfire
=========================Directory path can not be Chinese==================================
When Steps To Designated license server, Select the Locked license file (Server is not running)
1> Open license.dat then replace all string"00-00-00-00-00-00" with your PTC_HOST_ID(MAC address jusr Your netcard physical address) then save.
2> Install your pro/E &pro/M wildfire with above modified license file.Node Locked license method and No license server installaion needed.
2.Run patchs!
Aut proe-patch.exe under directory :
<Installed location>\proeWildfire 4.0\i486_nt\obj       then apply it.
But prom-patch1.exe under directory :
<Installed location>\proeWildfire 4.0\mech\i486_nt\bin      then apply it.
Cut prom-patch2.exe under directory :
<Installed location>\proeWildfire 4.0\mech\i486_nt\ptc      then apply it.
3.If you want install PTC Distributed Services,access PTC.Setup: other product->TC Distributed Services, use the modified license.dat at step one with node locked lic method. Then Put prods-patch.exe under directory :
<Installed location>\ptc_distributed_services\     then apply it.
发表于 2010-11-6 20:29 | 显示全部楼层
给你发过去了 你看看吧
GMT+8, 2025-11-7 09:48 , Processed in 0.118364 second(s), 38 queries .
