查看: 4487|回复: 4
[求助] proe有限元分析问题,请各位高手诊断
发表于 2010-8-17 07:33 | 显示全部楼层 |阅读模式
Mechanica Structure Version L-01-49:spg
Summary for Design Study "Analysis1"
Sun Aug 15, 2010   20:08:25
Run Settings
   Memory allocation for block solver: 128.0
Parallel Processing Status
   Parallel task limit for current run:            2
   Parallel task limit for current platform:      64
   Number of processors detected automatically:    2
Checking the model before creating elements...
These checks take into account the fact that AutoGEM will
automatically create elements in volumes with material
properties, on surfaces with shell properties, and on curves
with beam section properties.
   Generate elements automatically.
The design study terminated abnormally.
An internal engine error has occurred.  Please be sure
to run error checking before you run this study.  If
you have run error checking, then contact Customer Support.
Memory and Disk Usage:
   Machine Type: Windows NT/x86
   RAM Allocation for Solver (megabytes): 128.0
   Total Elapsed Time (seconds): 1.15
   Total CPU Time     (seconds): 0.83
   Maximum Memory Usage (kilobytes): 47069
   Working Directory Disk Usage (kilobytes): 0
   Results Directory Size (kilobytes):
   24524 .\Analysis1
78
发表于 2010-8-17 10:59 | 显示全部楼层
不是提示engine(引擎)出错,请运行错误检测,如果已进行,那请联系客户支持!建议方便的话重新检查你的安装。
只要自己尽心尽力就算啦。
 楼主| 发表于 2010-8-17 11:09 | 显示全部楼层
这个错误是在我换了电脑做时出现的,原来做没有问题,请问客户支持怎么联系?谢谢你。
发表于 2010-8-18 16:13 | 显示全部楼层
可能是破解不成功
或.DAT文件中的信息不对,新机器的网卡物理地址需要更新。
如果都不是,那么就不知道了。
花自飘零水自流,自寻烦恼在心头。。 。
《pro/engineer 4.0 /5.0 机械结构分析实战》
机械工业出版社 张洪涛编著
发表于 2010-8-18 17:12 | 显示全部楼层
回复 3# lpddpl0001 的帖子
那是按你的提示我的理解,咱们这些下载的软件很难享受到Customer Support
只要自己尽心尽力就算啦。
GMT+8, 2025-12-17 15:15 , Processed in 0.134696 second(s), 32 queries .
