查看: 3772|回复: 3
[求助] 关于Pro/Mechanica处理大模型失败的求助
发表于 2010-5-13 02:20 | 显示全部楼层 |阅读模式
最近做个分析没成。模型比较大,划分的网格多:
AutoGEM Summary
  Entities Created:
    Beam:         0             Edge:                    166917
    Tri:              0             Face:                    238503
    Quad:         0             Face-Face Link:    0
    Tetra:     103827       Edge-Face Link:    0
    Wedge:        0
    Brick:           0
失败的提示如下:
Fatal Error; Run Terminated
Wed May 12, 2010   13:17:33
An error has occurred while requesting an additional
2.48052 gigabytes of memory from the operating system.
To correct this problem, you may need to increase the amount
of swap space on your system.  You may also need to increase
the memory usage limits that are set for your system.
For large problems you can also try decreasing the
solram allocation setting.
At least 4.27322 gigabytes of memory are needed to run this design
study.
机子性能应该是可以的,具体如下:
CPU: Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz
显卡:NVIDIA GeForce 9800 GT  512M
内存:  物理内存总计: 3143788 KB   虚拟内存总计: 2097024 KB
Pro/Mechanica3.0 , Memary Allocation(MB)   设为51200
可还是失败了。请高手指教该如何设置?交换空间是指什么?
78
发表于 2010-5-18 10:46 | 显示全部楼层
想法:1.仅单纯的平面模型就划分成那么多单元,首先考虑能否简化模型去掉部分细节?不然Autogem为了收敛就在这些地方划分了较细的单元,这就增加了单元的数量与计算量。
2.memory Allocation(MB)怎么分配成51200M(51200兆??)了?你是在运行设置处临时设置的吗系统提示你你的物理内存总共还差2.48052gigabytes才能达到你的51200M。
3.若有不妥,请指正。
发表于 2010-5-31 17:10 | 显示全部楼层
发表于 2010-6-3 15:45 | 显示全部楼层
我也遇到了这样的问题!怎么解决啊?
GMT+8, 2025-12-2 18:34 , Processed in 0.116922 second(s), 25 queries .
