查看: 7230|回复: 2
[已解决] 模型分析错误求解 “insufficiently constrained”
发表于 2010-3-12 11:17 | 显示全部楼层 |阅读模式
请问各位大侠,下面的错误是怎么回事,我试了多个模型都有这个问题。
The model is insufficiently constrained for the analysis. Please review the element connections,
properties, and constraints in highlighted entities. If this is a modal analysis, then you may be
able to obtain a solution by requesting additional modes.
Source: Solver
发表于 2010-3-12 11:32 | 显示全部楼层
就是约束不足,有刚体位移了,好好检查一下单元之间是否连接正确(这个经常发生,如果几何处理不好的话),或看看施加的位移约束是否足够。
 楼主| 发表于 2010-3-15 10:18 | 显示全部楼层
谢谢,问题已经解决了,是原来的材料没有定义泊松比和杨氏模量
GMT+8, 2025-12-2 16:52 , Processed in 0.112806 second(s), 25 queries .
