查看: 18147|回复: 7
[已解决] Pro/E 5.0 M010无法启动 显示Warning Message List
发表于 2010-1-27 09:40 | 显示全部楼层 |阅读模式
本人己经多次检查过ptc_licfile.dat或`license.dat了,并试过修改安装目录中的D:\PTC\proeWildfire 5.0\bin\proe1.psf
也复制破解补丁到安装目录了,但仍不行!
请各位有经验的大侠不吝赐教,谢谢!
内部有一个文本说明为:boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.5.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.5.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
       <pro/m installdir>\i486_nt\obj
       <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.5.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
本人己将ptc.pro engineer.wildfire.5.0-patch.exe复制到<安装目录>\i486_nt\obj下面并运行
己将ptc.distributed.services.5.0-patch.exe 复制到<pro/ds 安装目录>\i486_nt\obj
己将ptc.pro mechanica.wildfire.5.0-patch.exe复制到
<pro/mechanica安装目录>\i486_nt\bin
<pro/mechanica安装目录>\i486_nt\ptc
(无法找到“pro/mechanica安装目录>\i486_nt\obj:故未复制)
同样也无法找到 说明文档中的<安装目录>\bin\proev.bat 文件
以上为本人自述,望得到帮助,深谢!
[ 本帖最后由 浪飘518 于 2010-1-27 10:55 编辑 ]
为了 理想的生活
发表于 2010-1-27 10:29 | 显示全部楼层
http://www.proewildfire.cn/thread-4774-1-1.html,看看这边吧,可能有你的答案,5.0用的人少, 曲高和寡啊
 楼主| 发表于 2010-1-27 10:38 | 显示全部楼层
嗯,谢谢啦 ,现在他们在用M020的啦 呵呵,我正准备试试呢
为了 理想的生活
 楼主| 发表于 2010-1-27 10:54 | 显示全部楼层
而且你发的那个贴我己经去看过了,没有我要的内容啊!肯请高人相助,小弟将不胜感激!
为了 理想的生活
发表于 2010-1-27 11:49 | 显示全部楼层
怎么能找不到OBJ文件夹?最主要的就是要复制到>\i486_nt\obj下面运行下补丁文件
发表于 2010-1-27 11:52 | 显示全部楼层
   这个运行的时候弹出对话框就选择否,一直等待运行完毕
 楼主| 发表于 2010-1-27 12:29 | 显示全部楼层
回楼上的,的确是一直选否,直至运行完毕!显示为PATCHING DONE!然后我才点击EXIT退出的!
为了 理想的生活
 楼主| 发表于 2010-1-27 12:57 | 显示全部楼层
我刚才在资源下载处重新下载了WIN32的破解补丁,己破解成功了,哈哈,原来我下载的软件的破解补丁不对,真的很感谢野火论坛!感谢野火所有的管理人员和上传人员!谢谢
为了 理想的生活
GMT+8, 2025-11-6 17:57 , Processed in 0.086679 second(s), 26 queries .
