查看: 12636|回复: 2
[求助] 谁有MAGNiTUDE组织更新的野火3.0许可证(无时间限制,全模块)
发表于 2010-1-18 09:52 | 显示全部楼层 |阅读模式
悬赏5金钱未解决
PTC.PRO.ENGINEER.WILDFIRE.V3.0.WORKiNG.CRACK.FiX.READ.NFO-MAGNiTUDE:
PTC Wildfire 3.0-F000 (32 & 64 bit)
The ZWTiSO release has several items not working:
a) The ZWTiSO release has no distributed services functionality. This is because the license features
  are incorrectly written with a suffix. There is no DS_SERVICE or DS_MANAGER to license as per the wf3.bmp.
b) The ZWTiSO release does not contain a full licensed version of Advanced Vericut. As of Wildfire 3.0 the advanced
  functionality of Vericut is now licensed through a CGTech license.
Installation:
1) In the crack directory open the file called ptc.dat and host to your computer name and 00-00-00-00-00-00
  to you host ID. Run keygen.bat which will create a license.dat.
2) Run setup and Install the Ptc License manager. Browse to the license.dat file created in step #1.
3) Run setup and install Pro/e, and optionally, Pro Mechanica and Distributed Services.
4) Copy the "PTC_WF3.exe" or "PTC_WF3_x64.exe" patcher to the following directories and run it:
  32 bit:
  - Pro/e: x:\Program Files\proeWildfire 3.0\i486_nt\obj
  - Pro/Mechanica: x:\Program Files\mechWildfire 3.0\i486_nt\bin
  - Distributed Services: x:\Program Files\ptc_distributed_services\i486_nt\obj
  64 bit:
  - Pro/e: x:\Program Files\proeWildfire 3.0\x86e_win64\obj
  - Pro/Mechanica: x:\Program Files\mechWildfire 3.0\x86e_win64\bin
  - Distributed Services: x:\Program Files\ptc_distributed_services\x86e_win64\obj
5) To full license Vericut (32 bit only) copy "WF3_VC544.exe" to x:\Program Files\proeWildfire 3.0\i486_nt\obj and run it.
  Also edit \x:\Program Files\proeWildfire 3.0\bin\proev.bat and edit the 3rd to last line in the file
  (add the comment "PTC_KEY=0").
  e.g. %start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;
    %CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0
发表于 2010-1-18 20:55 | 显示全部楼层
proe 野火4.0和3.0最新许可!
http://www.proewildfire.cn/thread-22309-1-1.html
这个试试吧,不过各组织的补丁好像都很好用
 楼主| 发表于 2010-1-19 08:51 | 显示全部楼层
邓议会,回家试试看,现谢谢啦
不知道是不是浮动de了。
GMT+8, 2025-11-7 09:27 , Processed in 0.106207 second(s), 24 queries .
