查看: 4586|回复: 1
[求助] 分析时警告:Two faces on opposite surfaces in a contact are connected at a node
发表于 2009-9-5 12:35 | 显示全部楼层 |阅读模式
分析的时候出现这样的警告:
** Warning: Two faces (DBIDs: 8601788 & 8537338) on opposite
            surfaces in a contact (DBID: 8362146) are
            connected at a node (DBID: 8363110). This prevents
            the surfaces from moving completely apart during
            a contact analysis. If this is not what you
            intended, please edit your model appropriately.
请问这是什么意思啊,是接触有问题吗?怎么解决啊?
发表于 2009-9-5 16:55 | 显示全部楼层
最好能贴个图,大家好分析,或者上传part
GMT+8, 2025-12-2 16:27 , Processed in 0.127534 second(s), 24 queries .
