查看: 7985|回复: 11
[求助] 求助版主一个结构分析的问题
发表于 2009-9-2 09:28 | 显示全部楼层 |阅读模式
Mechanica Structure Version L-01-48:spg
Summary for Design Study "yougangfenxi_700000"
Wed Sep 02, 2009   09:12:49
Run Settings
   Memory allocation for block solver: 128.0
Parallel Processing Status
   Parallel task limit for current run:            4
   Parallel task limit for current platform:      64
   Number of processors detected automatically:    4
Checking the model before creating elements...
These checks take into account the fact that AutoGEM will
automatically create elements in volumes with material
properties, on surfaces with shell properties, and on curves
with beam section properties.
   Generate elements automatically.
Checking the model after creating elements...
No errors were found in the model.
Mechanica Structure Model Summary
   Principal System of Units: millimeter Newton Second (mmNs)
   Length:          mm
   Force:           N
   Time:            sec
   Temperature:     C
   Model Type: Three Dimensional
   Edges:               23386
   Faces:               35069
   Springs:                 0
   Masses:                  0
   Beams:                   0
   Shells:                  0
   Solids:              15787
   Elements:            15787
   Contacts:        13
Standard Design Study
Static Analysis "yougangfenxi_700000":
Contact Analysis
   Convergence Method: Single-Pass Adaptive
   Plotting Grid:      4
The design study terminated abnormally.
2448932   is the DBID of an element for which outward normal could not be computed.
dotP = -3.573336e-003
Memory and Disk Usage:
   Machine Type: Windows NT/x86
   RAM Allocation for Solver (megabytes): 128.0
   Total Elapsed Time (seconds): 99.57
   Total CPU Time     (seconds): 99.12
   Maximum Memory Usage (kilobytes): 189944
   Working Directory Disk Usage (kilobytes): 0
   Results Directory Size (kilobytes):
   48016 .\yougangfenxi_700000
Run Completed with Fatal Error
Wed Sep 02, 2009   09:14:28
 楼主| 发表于 2009-9-2 09:29 | 显示全部楼层
这个问题是什么原因啊
怎么解决啊
对了,网格是可以划分的
发表于 2009-9-2 09:33 | 显示全部楼层
   Plotting Grid:      4
这是问题关键,最好把part传上来大家看一下!!
[ 本帖最后由 lhca 于 2009-9-2 09:34 编辑 ]
发表于 2009-9-2 09:34 | 显示全部楼层
没有错误提示
 楼主| 发表于 2009-9-2 09:36 | 显示全部楼层
没有错误提示啊
这已经是proe的运行状态记录文件了
 楼主| 发表于 2009-9-2 09:38 | 显示全部楼层
文件很大的,不知道大家以前有没有碰到过这种情况啊
发表于 2009-9-2 09:40 | 显示全部楼层
原帖由 darkhourse 于 2009-9-2 09:38 发表
贴个图,感觉还是和网格有关。
发表于 2009-9-2 09:59 | 显示全部楼层
原帖由 darkhourse 于 2009-9-2 09:36 发表
没有错误提示啊
这已经是proe的运行状态记录文件了
没有错误提示吗???
图来了
GMT+8, 2025-12-2 16:27 , Processed in 0.128428 second(s), 27 queries .
