查看: 3627|回复: 2
[分享] proe wildfire 4.0一闪就消失无法启动问题
发表于 2009-6-16 21:20 | 显示全部楼层 |阅读模式
Resolutions:
This issue happened when there are two different versions of Pro/ENGINEER installed on one machine and they are share the same cache.
To resolve this issue, there are two ways:
One way is to delete the cache before startup Pro/ENGINEER Wildfire 4.0.
>> Browse to C:\Documents and Settings\Administrator(or your login name)\Application Data\PTC\ProENGINEER\Wildfire\.wf, delete the .wf folder.
>> If you had set system environment PTC_WF_ROOT, please delete the folder under PTC_WF_ROOT.
The other way is to add system environment at Pro/ENGINEER Wildfire 4.0 startup command.
>> Open the Pro/ENGINEER startup file .psf (at <proe_loadpoint>\bin folder) with wordpad, add a line "ENV=PTC_WF_ROOT=D:\workspace\windchill\Forwf4", the value D:\workspace\windchill\Forwf4 is the path for writing cache
野火 + 1 感谢分享
 楼主| 发表于 2009-6-16 21:23 | 显示全部楼层
方法1:
删除 C:\Documents and Settings\Administrator(or your login name)\Application Data\PTC\ProENGINEER\Wildfire\.wf文件夹
方法2:
打开BIN下面的XXXX.PSF
增加"ENV=PTC_WF_ROOT=D:\workspace\windchill\Forwf4",
发表于 2009-6-17 07:36 | 显示全部楼层
论坛以前也发表过,感谢朋友分享!
GMT+8, 2025-11-5 09:46 , Processed in 0.124509 second(s), 26 queries .
