查看: 3495|回复: 3
[求助] Wildfire 2.0 license server 不能启动
发表于 2008-3-13 00:36 | 显示全部楼层 |阅读模式
23:56:19 (lmgrd) -----------------------------------------------
23:56:19 (lmgrd)   Please Note:
23:56:19 (lmgrd)
23:56:19 (lmgrd)   This log is intended for debug purposes only.
23:56:19 (lmgrd)   There are many details in licensing policies
23:56:19 (lmgrd)   that are not reported in the information logged
23:56:19 (lmgrd)   here, so if you use this log file for any kind
23:56:19 (lmgrd)   of usage reporting you will generally produce
23:56:19 (lmgrd)   incorrect results.
23:56:19 (lmgrd)
23:56:19 (lmgrd)
23:56:19 (lmgrd)
23:56:19 (lmgrd) Detecting other lmgrd processes...
23:56:21 (lmgrd) Done rereading
23:56:21 (lmgrd) FLEXlm (v8.4a) started on 270876083e9944d (IBM PC) (3/12/2008)
23:56:21 (lmgrd) Copyright (c) 1988-2003 by Macrovision Corporation. All rights reserved.
23:56:21 (lmgrd) US Patents 5,390,297 and 5,671,412.
23:56:21 (lmgrd) World Wide Web:  http://www.macrovision.com
23:56:21 (lmgrd) License file(s): G:\PTC\licensing\license.dat
23:56:21 (lmgrd) lmgrd tcp-port 27000
23:56:21 (lmgrd) Starting vendor daemons ...
23:56:21 (lmgrd) License daemon startup failed:
23:56:21 (lmgrd) File not found, G\PTC\flexlm\i486_nt\obj\ptc_d.exe
23:56:21 (lmgrd) Started ptc_d (pid 3472)
23:56:21 (ptc_d) Server started on 270876083e9944d for:        PROE_FLEX3C
23:56:21 (ptc_d) VERICUT_License MECSTRUCUI_License MECINTERFCE_License
23:56:21 (ptc_d) MECSTRUCENG_License MECTHERMUI_License MECTHERMENG_License
23:56:21 (ptc_d) MECMOTUI_License MECMOTENG_License MECEQRUN_License
23:56:21 (ptc_d) MECTIREMOD_License MECUG_License        WEBPUBLISH_License
23:56:21 (ptc_d) TMSINDA_License FLYTHRU_License MODELVIEW_License
23:56:21 (ptc_d) DESIGNER_License PAINT_License        ANIMATOR_License
23:56:21 (ptc_d) ILINK_CLIENT_License ILINK_TK_ACCESS_License ILINK_WEBCLIENT_License
23:56:21 (ptc_d) PROETRAIN_License MOCKUP_License        MOCKUPCONVERTER_License
23:56:21 (ptc_d) CDRSRENDER_License 2DGS-OA_License PVIEW_License
23:56:21 (ptc_d) RSDESIGNER_License MECBASICUI_License MECBASICENG_License
23:56:21 (ptc_d) DS_MANAGER        DS_SERVICE        PDM_License
23:56:21 (lmgrd) ptc_d using TCP-port 1093
这是什么问题?我很菜,请求帮助
367
芙蓉侍者
优秀斑竹勋章热心助人勋章宣传大使勋章斑竹勋章希望之星勋章
发表于 2008-3-13 00:51 | 显示全部楼层
换个许可证生成器试试!!
下面有:
http://www.proewildfire.cn/forum ... 6&highlight=2.0
这边也有:
http://www.proewildfire.cn/forum ... 2&highlight=2.0
我没用过2.0;你可以试试~~~
 楼主| 发表于 2008-3-13 20:32 | 显示全部楼层
装是装上了,又碰到问题了...不能启动,要我到bin里面找ptcsetup,说装了以后才能用...
发表于 2008-3-13 21:05 | 显示全部楼层
按提示是缺下面这个文件,所以不能启动
GMT+8, 2025-12-18 00:23 , Processed in 0.157063 second(s), 31 queries .
