查看: 3745|回复: 2
[转贴] Pro/E Wildfire 野火4.0 M010 (中/繁/英文正式版)
发表于 2008-3-12 23:12 | 显示全部楼层 |阅读模式
http://www.fmcax.com/down/2008/0312/down_1096.shtml
PTC Wildfire 4.0 M010
1. In the crack directory open the file called ptc.dat and 00-00-00-00-00-00 replace with your
   PTC host ID value (use "Program Files\proeWildfire 4.0\bin\ptchostid.bat" to get it).
   Run keygen.bat which will create a license.dat.
2. Run setup and install Pro/e, Pro Mechanica and Distributed Services.
   Select Locked licensing and point to license.dat created at step #1.
3. Copy the "PTC_WF4_Corrector.exe" to "Program Files\"and run it.
PS: You may run "Program Files\proeWildfire 4.0\bin\ptcsetup.bat" to set/change your WF4 setup.
[ 本帖最后由 wyw9898 于 2008-3-13 08:54 编辑 ]
367
芙蓉侍者
优秀斑竹勋章热心助人勋章宣传大使勋章斑竹勋章希望之星勋章
发表于 2008-3-13 00:53 | 显示全部楼层
楼主的意思是不是给个Pro/E Wildfire 野火4.0 M010 下载地址哈!~~
呵呵~~~
发表于 2008-3-13 08:55 | 显示全部楼层
回复 楼主 的帖子
呵呵,4.0M010出来了,只是上面那地址不能下载啊!
GMT+8, 2025-12-18 02:02 , Processed in 0.156096 second(s), 25 queries .
