查看: 4545|回复: 2
[已解决] 关于错误日志
发表于 2008-3-12 21:18 | 显示全部楼层 |阅读模式
我第一次运行pro/e就自动生成2个文件:
第一个为std错误日志,内容为
WARNING: MICROSOF-C75765 appears to have the loopback address 127.0.0.1 as IP address
This may imply that processes on MICROSOF-C75765 may not be able to connect to non-local processes
第二个为trail.txt  :内容为
!trail file version No. 1400
!Pro/ENGINEER  TM  Wildfire 4.0  (c) 1988-2002 by Wisdom Systems  All Rights Reserved.
< 0 0.881778 1141 0 0 744 1280 0 0 800 13
!mem_use INCREASE Blocks 170893, AppSize 24946425, SysSize 33309528
< 0 0.795259 944 0 0 671 1280 0 0 800 13
< 0 0.743111 902 0 0 627 1280 0 0 800 13
< 0 0.743111 872 0 0 627 1280 0 0 800 13
< 0 0.743111 831 0 0 627 1280 0 0 800 13
< 0 0.740741 831 0 0 625 1280 0 0 800 13
!%CI欢迎使用 Pro/ENGINEER Wildfire 4.0。
< 0 0.740741 835 0 0 625 1280 0 0 800 13
~ Activate `main_dlg_cur` `TAB_BROWSER_OPEN_NAME` \
~ Timer `UI Desktop` `UI Desktop` \
`EmbedBrowserTimer`
~ Command `ProCmdHelpAboutProE`
~ Activate `ptc_about` `Close`
~ Close `main_dlg_cur` `main_dlg_cur`
!Command ProCmdOSExit was pushed from the software.
! Message Dialog: Warning
!               : Pro/ENGINEER 将终止,并且所有未保存的工作将会丢失。
!               : 您确实要退出吗?
~ Activate `UI Message Dialog` `no`
~ Command `ProCmdModelNew`
~ Activate `new` `OK`
!Command ProCmdModelNewExe was pushed from the software.
!12-Mar-08 20:18:31  Start D:\feilvruan\ptc\4.0\templates\inlbs_part_solid.prt
!12-Mar-08 20:18:33  End   D:\feilvruan\ptc\4.0\templates\inlbs_part_solid.prt
!12-Mar-08 20:18:34  Start C:\Documents and Settings\Administrator\桌面\prt0001.prt.1
!12-Mar-08 20:18:34  End   C:\Documents and Settings\Administrator\桌面\prt0001.prt.1
!%CI用缺省模板D:\feilvruan\ptc\4.0\templates\inlbs_part_solid.prt作为模板。
< 0 0.740741 807 0 0 625 1280 0 0 800 13
~ Command `ProCmdUtilStartMechpost`
!%CE找不到 Mechanica 安装。某些功能将被禁用。
!               : 您确实要退出吗?
~ FocusIn `UI Message Dialog` `yes`
~ Activate `UI Message Dialog` `yes`
!End of Trail File
第二次运行又出现这两个文件,内容分别为
stdPro/ENGINEER is running with Unicode string encoding.
get_main_dialog:  no current active dialog (ORDER_DEBUG)
DUMMY - pro_set_input_devices_allowed
DUMMY - putxyres
pglSetStatus: Pgl Session Initialize
DUMMY - putxyres
uit_get_visual_style_low:  Style is Luna (NormalColor) (INFO MESSAGE)
ProCmdSelBufferAttrSet():  Selection Buffer Attribute loaded 40 commands (INFO MESSAGE)
cadds5_link_app_path_name():  NuTCRACKER is not installed (INFO MESSAGE)
check_exec_file_accessible_():  D:\feilvruan\ptc\4.0\\i486_nt\obj\SolidWorksConvert.exe not accessible (INFO MESSAGE)
PFSTMakeTypeString:  no zip found (INFO MESSAGE)
pro_locate_colormap ()
located color definition D:\feilvruan\ptc\4.0\graphic-library\appearances\appearance.dmt
located color definition D:\feilvruan\ptc\4.0\graphic-library\appearances\global.dmt
run mode = 2
pglSetStatus: Pgl Session Terminate
trail
!mem_use INCREASE Blocks 170884, AppSize 23455096, SysSize 36314824
~ Activate `main_dlg_cur` `main_dlg_cur`
~ Activate `main_dlg_cur` `resizer_button_1` \
< 0 0.740741 1088 0 0 625 1280 0 0 800 13
!               : 您确实要退出吗?
!End of Trail File
请问这些是怎么产生的,怎么处理?
[ 本帖最后由 dq-lb 于 2008-3-13 12:08 编辑 ]
110
优秀斑竹勋章热心助人勋章宣传大使勋章斑竹勋章希望之星勋章
发表于 2008-3-13 08:17 | 显示全部楼层
回复 楼主 的帖子
如果proe运行正常的话,这些不用去管!std(错误日志)和trail.txt  (轨迹文件即是对操作proe整个过程的记录)是系统自动产生,可以用spurge定期删除(论坛里有很多相关帖子)!
 楼主| 发表于 2008-3-13 12:07 | 显示全部楼层
谢谢版主,我原以为这些不正常呢!
GMT+8, 2025-12-18 02:07 , Processed in 0.155578 second(s), 29 queries .
