查看: 6491|回复: 3
[求助] mechanica中对称约束怎么设置
发表于 2009-6-7 09:14 | 显示全部楼层 |阅读模式
mechanica的位移约束中 对称约束如何设置?
发表于 2009-6-7 14:02 | 显示全部楼层
help中对称约束说明:
Symmetry Constraints
Use the Insert>Symmetry Constraint command in the Structure or Thermal module of native mode to create a cyclic or mirror symmetry constraint. This command is not available in FEM mode. When you select this command, the Symmetry Constraint dialog box appears with these items:
Name — The name of the constraint.
Member of Set — The name of the constraint set (in Structure) or boundary condition set (in Thermal). You can select an existing set from the drop-down list, or create a new set by clicking New to display the Constraint Sets dialog box.
Type — Select one of the following constraint types. The dialog box changes depending upon your selection:
Cyclic
Mirror (Structure only)
References — For mirror constraints, you can select points, vertices, curves, edges, or surfaces to define the plane of symmetry.
For cyclic constraints, you must make the following selections:
First Side — Define the first side of the cut section.
Second Side — Define the second side of the cut section.
Axis — Select the axis of symmetry. Axis is inactive if the software automatically determines the axis of symmetry.
A constraint set can include cyclic and mirror symmetry constraints, with these limitations:
The constraint set can include only one cyclic symmetry constraint.
The plane defining a mirror symmetry constraint must be orthogonal to the symmetry axis for a cyclic symmetry constraint.
You cannot use the same geometrical entity as a reference for a cyclic symmetry constraint and any other constraint.
上帝也疯狂!再怀念一下吧!
发表于 2009-7-31 23:17 | 显示全部楼层
怎么全英文的?
发表于 2009-8-2 09:40 | 显示全部楼层
先把零件切成你要分析的样子,选好对称面就可以了,要是旋转的要选两个面。
GMT+8, 2025-12-2 17:02 , Processed in 0.123927 second(s), 26 queries .
