查看: 3430|回复: 2
[原创] ProEwildfire4.0 M(080)安装
发表于 2009-5-16 08:01 | 显示全部楼层 |阅读模式
本人是个新手,郑重声明.
一、本人是文盲,对本人所发内容一概不能理解;
二、本人所发文字均来自sougou输入法,所发图片均自hypersnap软件,并不代表本人意见,如有任何法律问题,请直接联系软件作者;
三、本人所发内容仅供软件学习使用,请阅读者于看后24小时内忘记。
         !.下载M080.本版块有下载地址.
        @. 安装最新版的daemon tools,(可在天空下).安装需重启,别选插件.
          #.安装说明原文
            .boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
       <pro/m installdir>\i486_nt\obj
       <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
 楼主| 发表于 2009-5-16 08:09 | 显示全部楼层
%.用daemon tools载入下载的*.iso文件.
下面和这个一样
http://www.proewildfire.cn/thread-19748-1-1.html.
 楼主| 发表于 2009-5-16 17:11 | 显示全部楼层
没人回复
GMT+8, 2025-8-21 19:59 , Processed in 0.140019 second(s), 24 queries .
