查看: 2725|回复: 2
[求助] PROE 4.0 M50装好后自动结束程序
发表于 2009-5-7 14:29 | 显示全部楼层 |阅读模式
我郁闷啊,装好后在使用过程中,老是自动结束程序,没有任何提示,直接就死掉了,窗口消失了,这是怎么回事啊,我用的是XP系统.
 楼主| 发表于 2009-5-7 14:31 | 显示全部楼层
错误日志内容,高手看看
%UIMSG-USER-ERROR, Did not find resource translation file "animationlayout.txt"
%UIMSG-APPLICATION-ERROR, Component 'EMBED_BROWSER THREADS TAB@main_dlg_w1' is being resized when UI_redraw_Attr == FALSE
%UIMSG-APPLICATION-ERROR, Could not find component: EMBED_BROWSER_SEARCH_BTN, in device: main_dlg_w1, for inquire
%UIMSG-APPLICATION-ERROR, Did not find page <PHTLeft.Folders> in Tab PHTLeft.ProExplorerTab@main_dlg_w1
%UIMSG-APPLICATION-ERROR, Failed to modify component: PHTLeft.ProExplorerTab, in device: main_dlg_w1
%UIMSG-APPLICATION-ERROR, Component 'PHTLeft.PHFolders.sash_cmd_buttons@main_dlg_w1' is being resized when UI_redraw_Attr == FALSE
%UIMSG-APPLICATION-ERROR, Cannot modify the reverse horizontal placement flag
%UIMSG-APPLICATION-ERROR, Failed to modify global attributes
%UIMSG-USER-ERROR, Did not find resource translation file "regenstatusbar.txt"
%UIMSG-USER-ERROR, Did not find resource translation file "procmdsimprocguide.txt"
%UIMSG-APPLICATION-ERROR, Could not find component: Selobj_bin, in device: rmb_popup, for modify
%UIMSG-APPLICATION-ERROR, Could not find component: Selobj_rehil, in device: rmb_popup, for modify
发表于 2009-5-7 20:26 | 显示全部楼层
参考置顶帖里安装教程安装下
GMT+8, 2025-8-21 18:26 , Processed in 0.142647 second(s), 25 queries .
