查看: 4623|回复: 5
[求助] PROE4.0C000 启动问题
发表于 2009-2-14 14:41 | 显示全部楼层 |阅读模式
PROE4.0C000  安装好了,也破解好了。
但是用了几天好有个很奇怪的事,启动的时候出两个不认识的文件,而且启动到一半就自己死掉。后来再重新安装,都是这个情况?
谁知道是什么原因呢,谢谢
 楼主| 发表于 2009-2-14 14:58 | 显示全部楼层
启动时出现的文件
启动时候 出现了两个文件: 1 std.out     2   trail.txt
出现 这两个文件以后就启动停止了,自己关闭了。
 楼主| 发表于 2009-2-14 15:41 | 显示全部楼层
会不会跟CPU不是64位的有关系
会不会跟CPU不是64位的有关系
发表于 2009-2-14 17:41 | 显示全部楼层
std.out 用文本编辑器打开把内容贴上来看看
发表于 2009-5-7 15:51 | 显示全部楼层
haotie
发表于 2009-5-7 16:02 | 显示全部楼层
我的也是这样,我装的是.4.0 M50
pglSetStatus: Pgl Session Initialize
DUMMY - putxyres
uit_get_visual_style_low:  Style is luna (WindowBlindsColor) (INFO MESSAGE)
ProCmdSelBufferAttrSet():  Selection Buffer Attribute loaded 40 commands (INFO MESSAGE)
dll_get_func_ptr_msgq:  OS error 127 while getting ptr to 'gGetProtocolVersion' in 'gPlug' (ORDER_DEBUG)
cadds5_link_app_path_name():  NuTCRACKER is not installed (INFO MESSAGE)
check_exec_file_accessible_():  d:\Program Files\proeWildfire 4.0\\i486_nt\obj\SolidWorksConvert.exe not accessible (INFO MESSAGE)
PFSTMakeTypeString:  no zip found (INFO MESSAGE)
pro_locate_colormap ()
located color definition d:\Program Files\proeWildfire 4.0\graphic-library\appearances\appearance.dmt
located color definition d:\Program Files\proeWildfire 4.0\graphic-library\appearances\global.dmt
run mode = 2
prepare_named_object_retrieval:  overwriting retr_mode (INFO MESSAGE)
retrieving part mmns_part_solid ...
postread_corrupt_bkp_dims:  Checking model for dim corruption MMNS_PART_SOLID. (INFO MESSAGE)
File: Solid MMNS_PART_SOLID, type 2, generic , status = override
postread_pro_dls:  solid_silhouettes display list released (INFO MESSAGE)
postread_pro_dls:  spin icon display list released (INFO MESSAGE)
P_object is UNSTABLE
P_object is STABLE
check_run_time_attrs:  unexpected run-time attribute 286 (ORDER_DEBUG)
check_run_time_attrs:  unexpected run-time attribute 289 (ORDER_DEBUG)
writing MMNS_PART_SOLID of type 2
retrieving part prt0001 ...
check_run_time_attrs:  unexpected run-time attribute 286 -- clearing. (ORDER_DEBUG)
check_run_time_attrs:  unexpected run-time attribute 289 -- clearing. (ORDER_DEBUG)
File: Solid PRT0001, type 2, generic , status = override
dbkey_get : invalid call, key = -1
W-promenu_on_button can not find PART-Move Dim
W-promenu_on_button can not find PART-Export
W-promenu_on_button can not find PART-List Declare
W-promenu_on_button can not find PART-Shrink Info
W-cannot find menuART and/or item:Surface to make accessible
relsym_data_own_vals_upd_once_mode_start:  Update Once mode already active (INFO MESSAGE)
get_cur_seloption_type:  Not set (ORDER_DEBUG)
Exception - code was -1073741819.
GMT+8, 2025-8-21 18:24 , Processed in 0.155795 second(s), 31 queries .
