查看: 13056|回复: 17
[原创] 用了6年的PROE配置文件config.pro。---------经典---从没见过这么全的配置
发表于 2020-6-15 08:48 | 显示全部楼层 |阅读模式
分享了6年的config.Pro文件,打印,颜色,快捷键设置一应俱全。
drawing_setup_file $pro_directory\text\iso.dtl
format_setup_file $pro_directory\text\iso.dtl
pro_unit_length unit_mm
pro_unit_mass unit_gram
pro_unit_sys mmns
template_designasm $pro_directory\templates\mmns_asm_design.asm
template_drawing $pro_directory\templates\a4_drawing.drw
template_sheetmetalpart $pro_directory\templates\mmns_part_sheetmetal.prt
template_solidpart $pro_directory\templates\mmns_part_solid.prt
template_mfgmold $pro_directory\templates\mmns_mfg_mold.asm
template_mfgcast $pro_directory\templates\mmns_mfg_cast.asm
template_mfgcmm $pro_directory\templates\mmns_mfg_cmm.asm
template_mfgemo $pro_directory\templates\mmns_mfg_emo.asm
template_mfgnc $pro_directory\templates\mmns_mfg_nc.asm
template_mold_layout $pro_directory\templates\mmns_mold_lay.asm
template_cnfg_asm $pro_directory\templates\mmns_csa.asm
template_module $pro_directory\templates\mmns_asm_module.asm
tolerance_standard iso
tolerance_class fine
weld_ui_standard iso
orientation isometric
pen1_line_weight 1
pen2_line_weight 1
pen3_line_weight 1
pen4_line_weight 1
pen5_line_weight 1
pen6_line_weight 1
pen7_line_weight 1
pen8_line_weight 1
pdf_use_pentable yes
display SHADEWITHEDGES
display_coord_sys no
display_coord_sys_tags yes
display_axes no
display_axis_tags yes
display_planes no
display_plane_tags yes
display_points no
display_point_tags yes
spin_center_display no
display_annotations YES
display_mapkeys_dialog_on_top yes
display_popup_viewer Yes
spin_with_part_entities yes
measure_dialog_expand yes
max_animation_time 0.5
prehighlight_tree yes
sketcher_starts_in_2d yes
auto_add_remove yes
default_draw_scale 1
allow_move_view_with_move yes
rename_drawings_with_object both
save_texture_with_model yes
intf_out_layer block_nested_view_based_layer
preferred_export_format dwg
dwg_export_format 2004
dxf_export_format 2004
step_appearance_layers_groups yes
export_3d_force_default_naming yes
creo_less_restrictive_names yes
button_name_in_help yes
enable_absolute_accuracy yes
simprep_default_model_status master
edge_display_quality high
enable_fsaa 8
shade_quality 10
startup_check_for_visualization no
open_window_maximized yes
allow_confirm_window no
last_session_retrieval no
system_colors_file C:\Program Files\PTC\Creo 3.0\F000\Common Files\text\Syscol.scl
mdl_tree_cfg_file C:\Program Files\PTC\Creo 3.0\F000\Common Files\text\Tree.cfg
trail_dir C:\Program Files\PTC_Data\Creo_3.0_Data\Trail_dir
mapkey(continued) ~ Select `main_dlg_cur` \
mapkey(continued) `igToolbar_AncestorIGT_IGT_GRP_inh397369119.proe_win:casc340798662`;\
mapkey(continued) ~ Close `main_dlg_cur` \
mapkey(continued) ~ Command `ProCmdNamedViewsGalSelect`  `FRONT`;~ Command `ProCmdViewRefit`;
mapkey(continued) ~ Command `ProCmdNamedViewsGalSelect`  `BACK`;~ Command `ProCmdViewRefit`;
mapkey(continued) ~ Command `ProCmdNamedViewsGalSelect`  `LEFT`;~ Command `ProCmdViewRefit`;
mapkey(continued) ~ Command `ProCmdNamedViewsGalSelect`  `RIGHT`;~ Command `ProCmdViewRefit`;
mapkey(continued) ~ Command `ProCmdNamedViewsGalSelect`  `TOP`;~ Command `ProCmdViewRefit`;
mapkey(continued) ~ Command `ProCmdNamedViewsGalSelect`  `BOTTOM`;~ Command `ProCmdViewRefit`;
mapkey(continued) ~ Command `ProCmdNamedViewsGalSelect`  `Standard Orientation`;\
mapkey(continued) ~ Command `ProCmdViewRefit`;
mapkey(continued) ~ Command `ProCmdViewOrient` ;~ Open `orient` `SetupOptions`;\
mapkey(continued) ~ Close `orient` `SetupOptions`;\
mapkey(continued) ~ Select `orient` `SetupOptions` 1 `dynorient`;\
mapkey(continued) ~ Activate `orient` `NmViewCheckBtn` 1;\
mapkey(continued) ~ Select `orient` `namedviewPH.NameVw_List` 1 `Standard Orientation`;\
mapkey(continued) ~ Activate `orient` `namedviewPH.NameVw_List` 1 `Standard Orientation`;\
mapkey(continued) ~ Select `orient` `spinPH.SpinTypeRadio` 1 `XYZ`;\
mapkey(continued) ~ Update `orient` `spinPH.XSpinBox` -90.000000;~ Activate `orient` `OkPB`;\
mapkey(continued) ~ Update `orient` `spinPH.XSpinBox` -90.000000;\
mapkey(continued) ~ Update `orient` `spinPH.YSpinBox` 180.000000;~ Activate `orient` `OkPB`;\
mapkey(continued) ~ Command `ProCmdMakeActive`;
mapkey(continued) ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
mapkey(continued) ~ Close `rmb_popup` `PopupMenu`;\
mapkey(continued) ~ Command `ProCmdOpenModel@PopupMenuGraphicWinStack`;
mapkey(continued) ~ Command `ProCmdWinCloseGroup`;
mapkey(continued) ~ Activate `main_dlg_cur` `NavigatorOpenCloseChkBtn` 1;
mapkey 1 @MAPKEY_NAME_恢复默认主表示;@MAPKEY_LABEL_恢复主表示;\
mapkey(continued) ~ Command `ProCmdViewVisTool` ;~ Activate `visual_dlg0` `PropertiesBtn`;\
mapkey(continued) ~ Select `visual_dlg0` `RadioSelApplMgr` 1 `simplified rep`;\
mapkey(continued) ~ Arm `visual_dlg0` `Table` 2 `master rep` `name_column`;\
mapkey(continued) ~ Select `visual_dlg0` `Table` 2 `master rep` `name_column`;\
mapkey(continued) ~ Activate `visual_dlg0` `Table` 2 `master rep` `name_column`;
mapkey 2 @MAPKEY_NAME_将选中的元件设为主表示;@MAPKEY_LABEL_主表示;\
mapkey(continued) ~ Command `ProCmdViewVisTool` ;~ Command `ProCmdViewNormalMaster`;
mapkey 3 @MAPKEY_NAME_将选中的元件设为排除表示;@MAPKEY_LABEL_排除表示;\
mapkey(continued) ~ Command `ProCmdViewExclude`;
mapkey 4 @MAPKEY_NAME_将选中的元件设为透明样式;@MAPKEY_LABEL_透明样式;\
mapkey(continued) ~ Command `ProCmdViewTranspShaded`;;
mapkey 5 @MAPKEY_NAME_恢复默认主样式;@MAPKEY_LABEL_恢复主样式;\
mapkey(continued) ~ Select `visual_dlg0` `RadioSelApplMgr` 1 `display style`;\
mapkey(continued) ~ Arm `visual_dlg0` `Table` 2 `master style` `name_column`;\
mapkey(continued) ~ Select `visual_dlg0` `Table` 2 `master style` `name_column`;\
mapkey(continued) ~ Activate `visual_dlg0` `Table` 2 `master style` `name_column`;
mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg` ;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `colors_layouts`;\
mapkey(continued) ~ Open `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu`;\
mapkey(continued) ~ Close `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu` 1 `1`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;
mapkey(continued) ~ Select `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu` 1 `5`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `colors_layouts.Color_scheme_optMenu` 1 `2`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;options_dialog` `OkPshBtn`;
template_new_ecadasm D:\Program Files\PTC\Creo 6.0.4.0\Common Files\templates\mmks_ecad_asm.asm
template_boardpart D:\Program Files\PTC\Creo 6.0.4.0\Common Files\templates\mmks_ecad_board.prt
todays_date_note_format %Mmm-%dd-%yy
search_path_file $CREO_COMMON_FILES\afx\parts\prolibrary\search.pro
!PTC_Creo_Parametric_3.0_Config.pro
参与人数 1威望 +1 金钱 +4 收起 理由
野火 + 1 + 4 感谢分享
发表于 2020-6-15 15:32 | 显示全部楼层
很给力!
发表于 2020-6-16 08:52 | 显示全部楼层
感谢分享!
发表于 2020-6-16 23:40 | 显示全部楼层
学习了
发表于 2020-6-18 12:11 | 显示全部楼层
要的是精髓,要全直接导出内置的参数文件合并在一起就行了
发表于 2020-6-20 16:35 | 显示全部楼层
给力
发表于 2020-6-20 17:03 | 显示全部楼层
学习了。
发表于 2020-6-20 17:46 | 显示全部楼层
这些是做什么的呀,这么多!
发表于 2020-6-21 09:07 | 显示全部楼层
感谢分享!
发表于 2021-7-24 16:53 | 显示全部楼层
感谢分享!
GMT+8, 2025-12-18 01:51 , Processed in 0.186563 second(s), 26 queries .
