楼主 |
发表于 2008-12-22 13:14
显示全部楼层
我按里面的方法做了 还是没用 2.0的我会装 至于3.0的我以前也安装过 还是刚出3.0的时候 他那个破解的 好象不是现在
ptc.distributed.services.generic-patch软件 以前我装的是替换D:\3.0PRO\i486_nt\obj下的xtop这个就行了 我感觉这个破解有问题
还有我觉的ptc.distributed.services.generic-patch软件在4.0里有用 我刚装了4.0成功了 是不是4.0的破解啊 ?
还有就是至于先装PRO程序还是在LIC我知道 在UG里是装LIC 在装程序的 这我知道的 现在就是不懂怎么安装不了M180的
要不看下我的 LIC文件
# replace 00-10-5C-D9-D4-3D in every-feature with your actual ptc_hostid
# as shown in setup
INCREMENT PROE_DDiTy ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(0,3,6,7,9,10,14,16,17,19,21,22, \
23,24,25,26,29,30,31,32,34,35,36,37,40,41,45,47,48,51,52,53, \
54,55,56,57,59,60,61,62,63,65,66,67,69,71,72,73,74,77,91,92, \
93,94,97,100,104,106,108,115,116,117,118,119,120,121,122,123, \
125,126,127,128, 131,133,134,135, 137,139,140,141,148,155,156, \
158,160,163,164,167,168,187,188,189,190, 191,192,193,194,208,209,210, \
213,214,218,219,220,221,222,223,224,251,253)" SUPERSEDE \
HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D vendor_info="VIVER=2.0 EXTERNAL_NAME=" ISSUER=ODT \
ISSUED=2-apr-2006 NOTICE=PTC SN=07071982 SIGN="092F DBD8 F7BA \
EC9D 51E5 453C 93A1 D63D 0BC7 3126 8493 2C23 32A9 A98F 8BC0 1BEB \
0F0F 5C63 6933 5B61 613F 0CFB 235B 9C1B B39E 274F 2E5A 60E1 1FEF \
DE6A" SIGN2="092F DBD8 F7BA EC9D 51E5 453C 93A1 D63D 0BC7 3126 \
8493 2C23 32A9 A98F 8BC0 1BEB 0F0F 5C63 6933 5B61 613F 0CFB 235B \
9C1B B39E 274F 2E5A 60E1 1FEF DE6A"
INCREMENT MECBASICUI_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,157,211)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECBASICENG_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,161,212)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECSTRUCUI_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,81,157,159,161)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECSTRUCENG_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,82,85,157,161)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECMOTUI_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,86,89,159)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECMOTENG_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,79,87,89)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECTHERMUI_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,83,159)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECTHERMENG_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,84)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECINTERFCE_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,80)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECTIREMOD_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,90)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECUG_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MECEQRUN_12345 ptc_d 27.0 permanent uncounted \
INCREMENT 2DGS-OA_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,169,170,171, \
172,173,174,175,176,177,178,179,180,181,182,183,184,185,186)" \
SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D vendor_info="VIVER=2.0 \
EXTERNAL_NAME=" ISSUER=ODT ISSUED=2-apr-2006 NOTICE=PTC SN=07071982 \
SIGN="092F DBD8 F7BA EC9D 51E5 453C 93A1 D63D 0BC7 3126 8493 2C23 \
32A9 A98F 8BC0 1BEB 0F0F 5C63 6933 5B61 613F 0CFB 235B 9C1B B39E \
274F 2E5A 60E1 1FEF DE6A" SIGN2="092F DBD8 F7BA EC9D 51E5 453C \
93A1 D63D 0BC7 3126 8493 2C23 32A9 A98F 8BC0 1BEB 0F0F 5C63 6933 \
5B61 613F 0CFB 235B 9C1B B39E 274F 2E5A 60E1 1FEF DE6A"
INCREMENT VERICUT_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,139,140,141)" \
INCREMENT WEBPUBLISH_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19)" \
INCREMENT FLYTHRU_12345 ptc_d 27.0 permanent uncounted \
INCREMENT FLYPLUGIN_12345 ptc_d 27.0 permanent uncounted \
INCREMENT FLYVIEWER_12345 ptc_d 27.0 permanent uncounted \
INCREMENT CONCEPT_12345 ptc_d 5.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,148)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT PROPACKENG_12345 ptc_d 27.0 permanent uncounted \
INCREMENT PROPACKUI_12345 ptc_d 27.0 permanent uncounted \
INCREMENT DS_MANAGER ptc_d 27.0 permanent uncounted \
INCREMENT DS_MANAGER-REP ptc_d 27.0 permanent uncounted \
INCREMENT DS_SERVICE ptc_d 27.0 permanent uncounted \
INCREMENT PROETRAIN_12345 ptc_d 27.0 permanent uncounted \
INCREMENT MOCKUPCONVERTER_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 \
LO=(19,149,150,151,152,153,154)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT MOCKUP_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,142,143,144,145,146,154)" \
SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D vendor_info="VIVER=2.0 EXTERNAL_NAME=" ISSUER=ODT \
INCREMENT MODELVIEW_12345 ptc_d 27.0 permanent uncounted \
INCREMENT PVIEW_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,166,195,215)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT RSDESIGNER_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,214)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT TMSINDA_12345 ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=(19,139,140,141)" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT INTERCOMM ptc_d 27.0 permanent uncounted \
VENDOR_STRING="VSVER=2.0 LO=()" SUPERSEDE HOSTID=PTC_HOSTID=00-10-5C-D9-D4-3D \
INCREMENT EDACONDUIT ptc_d 27.0 permanent uncounted \
INCREMENT EDACONNECTOR ptc_d 27.0 permanent uncounted \
我的ID 00-10-5C-D9-D4-3D
破解是 把SHooTERS下的ptc.distributed.services.generic-patch复制到D:\3.0PRO\i486_nt\obj下 运行也出现了 PATCHINC DONE但就是打不开 出现-8?
知道为什么吗 |
