1、倆个件的过盈配合
2、三个件的过盈配合
结果如下
Calculating Disp and Stress Results (21:39:31)
Post-Processing Solution (21:39:32)
Checking Convergence (21:39:32)
RMS Stress Error Estimates:
Load Set Stress Error % of Max Prin Str
LoadSet1 6.68e+03 0.9% of 7.56e+05
Resource Check (21:39:33)
Elapsed Time (sec): 273.36
CPU Time (sec): 262.27
Memory Usage (kb): 189683
Wrk Dir Dsk Usage (kb): 24578
Total Mass of Model: 3.948152e-05
Total Cost of Model: 0.000000e+00
Mass Moments of Inertia about WCS Origin:
Ixx: 1.95098e-02
Ixy: -2.72488e-04 Iyy: 1.93358e-02
Ixz: 5.80669e-05 Iyz: 9.28810e-05 Izz: 1.30332e-03
Principal MMOI and Principal Axes Relative to WCS Origin:
Max Prin Mid Prin Min Prin
1.97089e-02 1.91374e-02 1.30264e-03
WCS X: 8.07501e-01 5.89857e-01 -3.26699e-03
WCS Y: -5.89866e-01 8.07485e-01 -5.19985e-03
WCS Z: -4.29121e-04 6.12597e-03 9.99981e-01
Center of Mass Location Relative to WCS Origin:
(-1.18891e+00, -1.54161e+00, -1.53270e+01)
Mass Moments of Inertia about the Center of Mass:
Ixx: 1.01412e-02
Ixy: -2.00125e-04 Iyy: 1.00051e-02
Ixz: 7.77514e-04 Iyz: 1.02576e-03 Izz: 1.15368e-03
Principal MMOI and Principal Axes Relative to COM:
1.02847e-02 1.00478e-02 9.67421e-04
WCS X: 8.24591e-01 5.59097e-01 -8.63728e-02
WCS Y: -5.65690e-01 8.16666e-01 -1.14241e-01
WCS Z: 6.66615e-03 1.43062e-01 9.89691e-01
Constraint Set: ConstraintSet1
Load Set: LoadSet1
Resultant Load on Model:
in global X direction: -4.361330e-10
in global Y direction: -9.187736e-10
in global Z direction: -1.963495e+04
Measures:
contact_area: 2.012394e+01
contact_max_pres: 7.266375e+05
max_beam_bending: 0.000000e+00
max_beam_tensile: 0.000000e+00
max_beam_torsion: 0.000000e+00
max_beam_total: 0.000000e+00
max_disp_mag: 1.759785e+00
max_disp_x: -1.135114e+00
max_disp_y: -1.170505e+00
max_disp_z: -8.946233e-01
max_prin_mag: -7.563463e+05
max_rot_mag: 0.000000e+00
max_rot_x: 0.000000e+00
max_rot_y: 0.000000e+00
max_rot_z: 0.000000e+00
max_stress_prin: 9.714023e+04
max_stress_vm: 6.602694e+05
max_stress_xx: -7.080857e+05
max_stress_xy: -1.595013e+05
max_stress_xz: -3.676254e+04
max_stress_yy: -1.803296e+05
max_stress_yz: -7.182316e+04
max_stress_zz: -1.845201e+05
min_stress_prin: -7.563463e+05
strain_energy: 1.708097e+05
Contact1_area: 2.977759e+00
Contact1_max_pres: 7.266375e+05
Contact2_area: 1.714618e+01
Contact2_max_pres: 4.999157e+02
Analysis "Analysis2" Completed (21:39:33)
Memory and Disk Usage:
Machine Type: Windows NT/x86
RAM Allocation for Solver (megabytes): 128.0
Total Elapsed Time (seconds): 273.40
Total CPU Time (seconds): 262.31
Maximum Memory Usage (kilobytes): 189683
Working Directory Disk Usage (kilobytes): 24578
Results Directory Size (kilobytes):
2487 .\Analysis2
Maximum Data Base Working File Sizes (kilobytes):
2048 .\Analysis2.tmp\gapel1.bas
20480 .\Analysis2.tmp\kel1.bas
2048 .\Analysis2.tmp\oel1.bas
Run Completed
Mon Jan 21, 2008 21:39:33
