查看: 7492|回复: 5
[求助] CREO 4.0下载好了怎么安装
发表于 2017-1-17 14:09 | 显示全部楼层 |阅读模式
CREO 4.0下载好了怎么安装,哪位大神有安装视频或者说明,谢谢!!
热心助人勋章优秀会员勋章希望之星勋章嘉宾勋章
发表于 2017-1-17 17:54 | 显示全部楼层
CREO 4.0 安装破解方法
1. Unzip "PTC.LICENSE.WINDOWS-SSQ.7z" to temporary directory
   and run "FillLicense.bat". The "PTC_D_SSQ.dat" file near batch script
   contains the license file with correct PTC HOSTID will be generated
   Copy generated license file to folder of choice (for example, C:\Program Files\PTC)
  将"PTC.LICENSE.WINDOWS SSQ.7z"解压缩到临时目录
  然后运行"FillLicense.bat"批处理脚本,将生成正确的包含 PTC 主机 ID 的许可证文件"PTC_D_SSQ.dat"。
  将生成的许可证文件复制到一个文件夹,(例如,C:\Program Files\PTC)
2. Create enviroment variable PTC_D_LICENSE_FILE=<full path to PTC_D_SSQ.dat>
  创建环境变量 PTC_D_LICENSE_FILE = < PTC_D_SSQ.dat 的完整路径 >
3. Install PTC Creo 4.0 F000 Win64
  安装 PTC Creo 4.0 F000 Win64
3.1. Copy  folders "Distributed Services Manager", "F000" and "View Express" from "PTC.CREO.4.0.F000.WIN-SSQ.7z"\Creo 4.0 folder to <Creo 4.0 progdir> (by default C:\Program Files\PTC\Creo 4.0\ ) with overwrite
  1.从"PTC。CREO.4.0.F000.WIN-SSQ\Creo 4.0文件夹中复制"Distributed Services Manager"、"F000"和"View Express"文件夹到Creo 4.0的安装目录下(默认情况下 C:\Program Files\PTC\Creo 4.0\)覆盖并替换。
4. Install PTC Mathcad Prime 3.1 Win64 (optional)
  安装 PTC Mathcad Prime 3.1 Win64 (可选)
4.1. Replace original <Mathcad Prime 3.1 program folder> (by default C:\Program Files\PTC\Mathcad Prime 3.1 ) with cracked one from "PTC.CREO.4.0.F000.WIN-SSQ.7z"
  1 从"PTC.CREO.4.0.F000.WIN SSQ"文件夹复制 Mathcad Prime 3.1 文件夹到 Mathcad Prime 3.1 的安装目录(默认情况下 C:\Program Files\PTC\),覆盖并替换。
5. Run "SolidSQUADLoaderEnabler.reg" and confirm to add info into Windows Registry
  运行"SolidSQUADLoaderEnabler.reg"并确认要将信息添加到 Windows 注册表
6. REBOOT
  重新启动
7. Enjoy!
发表于 2017-1-17 18:38 | 显示全部楼层
应该和3.0的安装方法一样吧?
发表于 2017-1-17 20:02 | 显示全部楼层
我都下载不到
发表于 2017-1-19 12:53 | 显示全部楼层
在哪下载的
发表于 2018-1-17 19:49 | 显示全部楼层
4.0的安装和3.0完全不一样了
GMT+8, 2025-8-24 10:38 , Processed in 0.156850 second(s), 26 queries .
