查看: 5226|回复: 2
[求助] 新人求助,creo4.0下载了,请问怎么安装?
发表于 2016-12-29 09:12 | 显示全部楼层 |阅读模式
我已经下载了creo4.0,但是论坛里PTC Creo 4.0 M010~Mxxx 正式版安装图文教程这个点击进去显示error无法观看,请问有安装好的朋友吗?有没有教程,谢谢了!我全部下载了,总共大小有10.6G。
热心助人勋章优秀会员勋章希望之星勋章嘉宾勋章
发表于 2016-12-29 09:46 | 显示全部楼层
1. Unzip "PTC.LICENSE.WINDOWS-SSQ.7z" to temporary directory
   and run "FillLicense.bat". The "PTC_D_SSQ.dat" file near batch script
   contains the license file with correct PTC HOSTID will be generated
   Copy generated license file to folder of choice (for example, C:\Program Files\PTC)
  将"PTC.LICENSE.WINDOWS SSQ.7z"解压缩到临时目录
  然后运行"FillLicense.bat"批处理脚本,将生成正确的包含 PTC 主机 ID 的许可证文件"PTC_D_SSQ.dat"。
  将生成的许可证文件复制到一个文件夹,(例如,C:\Program Files\PTC)
2. Create enviroment variable PTC_D_LICENSE_FILE=<full path to PTC_D_SSQ.dat>
  创建环境变量 PTC_D_LICENSE_FILE = < PTC_D_SSQ.dat 的完整路径 >
3. Install PTC Creo 4.0 F000 Win64
  安装 PTC Creo 4.0 F000 Win64
3.1. Copy  folders "Distributed Services Manager", "F000" and "View Express" from "PTC.CREO.4.0.F000.WIN-SSQ.7z"\Creo 4.0 folder to <Creo 4.0 progdir> (by default C:\Program Files\PTC\Creo 4.0\ ) with overwrite
  1.从"PTC。CREO.4.0.F000.WIN-SSQ\Creo 4.0文件夹中复制"Distributed Services Manager"、"F000"和"View Express"文件夹到Creo 4.0的安装目录下(默认情况下 C:\Program Files\PTC\Creo 4.0\)覆盖并替换。
4. Install PTC Mathcad Prime 3.1 Win64 (optional)
  安装 PTC Mathcad Prime 3.1 Win64 (可选)
4.1. Replace original <Mathcad Prime 3.1 program folder> (by default C:\Program Files\PTC\Mathcad Prime 3.1 ) with cracked one from "PTC.CREO.4.0.F000.WIN-SSQ.7z"
  1 从"PTC.CREO.4.0.F000.WIN SSQ"文件夹复制 Mathcad Prime 3.1 文件夹到 Mathcad Prime 3.1 的安装目录(默认情况下 C:\Program Files\PTC\),覆盖并替换。
5. Run "SolidSQUADLoaderEnabler.reg" and confirm to add info into Windows Registry
  运行"SolidSQUADLoaderEnabler.reg"并确认要将信息添加到 Windows 注册表
6. REBOOT
  重新启动
7. Enjoy!
Cracked by TeAM SolidSQUAD-SSQ
发表于 2016-12-29 20:44 | 显示全部楼层
暂时没安装教程,你按楼上的安装说明装,遇到问题在论坛发帖交流
GMT+8, 2025-8-19 03:01 , Processed in 0.153620 second(s), 26 queries .
