楼主: pmiao
[分享] 百度云分享 PTC Creo 3.0 M030
发表于 2015-3-14 12:28 | 显示全部楼层
太感谢了,谢谢分享!!!!
发表于 2015-3-14 16:24 | 显示全部楼层
好快喔! 但目前 都還停留在野火4.0版
留著下次試用看看
謝謝!
发表于 2015-3-14 22:33 | 显示全部楼层
楼主破解文件是????
发表于 2015-3-14 22:45 | 显示全部楼层
找到了!!!!恩恩!!!谢谢楼主
发表于 2015-3-15 13:49 | 显示全部楼层
楼主破解提示File F:\PTC\Creo 3.0\M030\Common Files\creo_ui_editor\x86e_win64\obj\creo_ui_editor.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\mech\x86e_win64\bin\msengine.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\mech\x86e_win64\bin\showlic.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\mech\x86e_win64\ptc\ptcxfce.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\x86e_win64\obj\cpu_id.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\x86e_win64\obj\dbatchc.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\x86e_win64\obj\dsq.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\x86e_win64\obj\pfclscom.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\x86e_win64\obj\plpf_status.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\x86e_win64\obj\protk_unlock.exe NOT patched - check if you already patched it?
File F:\PTC\Creo 3.0\M030\Common Files\x86e_win64\obj\xtop.exe NOT patched - check if you already patched it?
 楼主| 发表于 2015-3-15 13:50 | 显示全部楼层
xu199367 发表于 2015-3-15 13:49
楼主破解提示File F:\PTC\Creo 3.0\M030\Common Files\creo_ui_editor\x86e_win64\obj\creo_ui_editor.exe  ...
是WIN8吗?破解要管理员
发表于 2015-3-16 14:55 | 显示全部楼层
谢谢
发表于 2015-3-17 11:46 | 显示全部楼层
百度的网盘就是比迅雷的快,谢谢分享。
发表于 2015-3-17 12:32 | 显示全部楼层
不知道好不好用
发表于 2015-3-18 17:11 | 显示全部楼层
十分感谢分享,原F000最近作图常退出,不知什么问题,换换这个体验一下!
GMT+8, 2025-8-18 20:31 , Processed in 0.176724 second(s), 30 queries .
