楼主: quanta
[求助] 紧急求助:Creo2.0 M080 安装显示xtop.exe not patched
发表于 2014-4-21 13:19 | 显示全部楼层
win7 64  旗舰版 creo2.0 安装一切正常  破解时出现这种情况
File D:\PTC\Creo 2.0\Common Files\M100\mech\x86e_win64\bin\mdb2mnf.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\mech\x86e_win64\bin\mech.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\mech\x86e_win64\bin\mnf2mdb.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\mech\x86e_win64\bin\msengine.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\mech\x86e_win64\bin\showlic.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\mech\x86e_win64\bin32\mech.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\mech\x86e_win64\ptc\ptcxfce.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\x86e_win64\obj\cpu_id.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\x86e_win64\obj\dsq.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\x86e_win64\obj\plpf_status.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\x86e_win64\obj\protk_unlock.exe NOT patched - check if you already patched it?
File D:\PTC\Creo 2.0\Common Files\M100\x86e_win64\obj\xtop.exe NOT patched - check if you already patched it?
全都是这样,请问是什么情况
发表于 2015-10-19 02:14 | 显示全部楼层
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\mech\x86e_win64\bin\msengine.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\mech\x86e_win64\bin\showlic.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\mech\x86e_win64\ptc\ptcxfce.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\cpu_id.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\dsq.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\plpf_status.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\protk_unlock.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\xtop.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\Distributed Services Manager\x86e_win64\obj\cpu_id.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\Distributed Services Manager\x86e_win64\obj\dsq.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\Distributed Services Manager\x86e_win64\obj\plpf_status.exe NOT patched - check if you already patched it?
我的也全是这情况
发表于 2016-3-23 10:23 | 显示全部楼层
tongqiu
GMT+8, 2025-8-18 22:41 , Processed in 0.126587 second(s), 29 queries .
