查看: 2377|回复: 1
[已解决] the draft plane
发表于 2008-9-13 16:22 | 显示全部楼层 |阅读模式
To create a draft tangent, the curve must be a child of (have a soft point on) the curve on the draft plane.  The second end of this curve does not have this condition so you will first need to switch the parent/child relationship before making the draft tangent.
各位大虾!如何转换父子关系,转换成什么父子关系才能使能"相切拔模"?
 楼主| 发表于 2008-9-13 16:59 | 显示全部楼层
问题已解决..
GMT+8, 2025-11-10 15:53 , Processed in 0.111453 second(s), 24 queries .
