查看: 6014|回复: 7
[求助] 基准及实体显示异常?
发表于 2012-12-4 17:41 | 显示全部楼层 |阅读模式
悬赏5金钱未解决
故障:鼠标一旦接触里面的基准平面以及实体(不论简单实体或者复杂实体),基准以及实体就会消失,实体只显示少部分线条。但是当用鼠标中键旋转实体时,实体却能完好显示。换了个WINXP系统,装了IE8,重装了PROE3.0。故障依旧。
我的电脑:
》core i3 2120 3.3g 集显HD2000
》华硕P8H61MLX3 R2.0
》内存2G DDR3 1333
》winxp professional版本2002service pack3
》雨林木风 Ghost XP SP3 装机版 YN9.9(补丁更新至2008年12月)
》ie8
》华硕原版驱动程序(芯片组,显卡,声卡,网络装齐了)
》运行photoshp9.0和CAD2008良好。
》已通过杀毒检测(AVAST和360——4.0正式版)
》按照野火论坛安装方法安装Pro_Engineer_3.0_M250_Win32-WXF3792
我六年前的电脑只是赛扬D加低端128M显卡就能运行(比较慢),为啥都换酷睿I3了却出了这个问题?
文件: support.inf.2
时间: 03-Dec-12 12:15:06
许可信息
配置号: 07071982
版本:Wildfire 3.0
Pro/ENGINEER 日期代码: M250
许可证名称ROE_DDiTy
许可证版本:27.0
许可证类型: Commercial version,Node-Locked License
服务器名称: NONE
许可证文件搜索路径:\ptc\license\license.dat
配置选项模块
装入了下列Pro/ENGINEER选项:
(注意:许可证扩展名标有'*')
ADVANCED_RENDER                 Pro/DESIGNER                    Pro/NCPOST-MILL
Advanced_Schematic              Pro/DETAIL                      Pro/NCPOST-SHTMTL
Behavioral_Modeler              Pro/DIAGRAM                     Pro/NCPOST-TURN
Chinese_Translation             Pro/DIEFACE                     Pro/NCPOST-WEDM
Collaboration                   Pro/E-TK-Gateway                Pro/NOTEBOOK
Declassifying_Data              Pro/ECAD                        Pro/ORACLE
Design_Animation                Pro/FEATURE                     Pro/PDA/COMBO
Expert_Framework                Pro/FEM-POST                    Pro/PHOTORENDER
Expert_Machinist                Pro/FLY-CONNECT                 Pro/PIPING
Expert_Moldbase                 Pro/FLY-EXPORT                  Pro/PLOT
Expert_Toolmaker                Pro/FLY-INTERFERENCE            Pro/PROCESS_ASM
INTF_for_CATIA_V5               Pro/FLY-MARKUP                  Pro/PROCESS_MFG
INTF_for_CATIA_V5_ADV           Pro/FLY-MEASURE                 Pro/PlasticAdvisor
INTF_for_I-DEAS                 Pro/FLY-MOTION                  Pro/REPORT
INTF_for_UG                     Pro/FLY-PLACEMENT               Pro/SCAN_TOOLS
Import_Data_Doctor              Pro/HARNESS-MFG                 Pro/SHEETMETAL
Interactive_Surface_Design      Pro/HPGL2                       Pro/SHEETMTL-DES
Mechanism_Design                Pro/INFOSOLIDIN                 Pro/STANDALONE
Mechanism_Dynamics              Pro/INTERFACE                   Pro/SURFACE
ModelCHECK                      Pro/INTF-CADDS5                 Pro/Structural_Hull
NC_Machine_Simulation           Pro/INTF-for-CAT                Pro/TOOLING
NC_Optimization                 Pro/INTF-for-CAT-II-w/ATB       Pro/TOOLKIT
NC_Verification                 Pro/INTF-for-VRML               Pro/TOOLKIT-for-3D_Drawings
NET_ANIMATOR                    Pro/INTF_for_STEP               Pro/TOOLKIT-for-Access_Solvers
ORDER_DEBUG                     Pro/ISOGEN                      Pro/TOOLKIT-for-Advanced_NC
Pro/4DNavigator                 Pro/LEGACY                      Pro/TOOLKIT-for-Mechanica
Pro/ANIMATE                     Pro/LIBRARYACCESS               Pro/VERIFY
Pro/ASSEMBLY                    Pro/MESH                        Pro/VERSATEC
Pro/ASSY_PERFORMANCE            Pro/MOLDDESIGN-2                Pro/WELDING
Pro/Basic_Hull                  Pro/MOLDESIGN                   Pro/Web.Link
Pro/CABLING                     Pro/NC-ADVANCED                 Pro/Web.Publish
Pro/CALCOMP                     Pro/NC-CHECK                    Pro/Zone_clipping
Pro/CASTING                     Pro/NC-MILL                     Progressive_Die
Pro/CDT                         Pro/NC-SHEETMETAL               Reverse_Engineering
Pro/CMM                         Pro/NC-TURN                     Thermal_Modeler
Pro/COMPOSITE                   Pro/NC-WEDM                     WISDOM
Pro/DATA_for_PDGS               Pro/NCPOST-ADVMFG               e/ENGINEER_Option
机械信息
主机名: WWW-320CAEFC119
用户名: Administrator
主机ID: 50-46-5D-58-A6-B6
Pro/ENGINEER机床类型: I486_NT
Pro/ENGINEER图形类型: OPENGL
使用硬件加速 OpenGL。
OS名: Windows NT
OS关系: 5.1
OS版本: 2600
硬件类型:  x86 Family 6 Model 42 Stepping 7  GenuineIntel  3300 MHz
安装目录和命令信息
目录:
Pro/ENGINEER安装目录: D:\ptc\proeWildfire 3.0\
Pro/ENGINEER启动目录: D:\ptc\work\
Pro/APPLICATION MANAGER目录: 不可用
Pro/INTRALINK目录: 不可用
命令:
Pro/ENGINEER启动命令: D:\ptc\proeWildfire 3.0\bin\proe.exe
配置信息
配置文件读取:
D:\ptc\proeWildfire 3.0\text\menu_def.pro
Pro/HELP搜寻路径: d:\Ptc\proeWildfire 3.0
辅助应用信息
没有装入辅助应用选项。
发表于 2012-12-4 20:18 | 显示全部楼层
安装下显卡驱动看看
发表于 2012-12-7 10:24 | 显示全部楼层
显卡问题
实体可以共享下
 楼主| 发表于 2012-12-7 12:18 | 显示全部楼层
是否?野火的安装程序有小部分的损坏?(因为我是存储在硬盘上的,如果硬盘有坏道,就会造成程序损坏)。
有无上述可能?
 楼主| 发表于 2012-12-7 12:19 | 显示全部楼层
原帖由 wwwsbh123 于 2012-12-7 10:24 发表
实体可以共享下
不用共享。随便建一个实体就会出现上述问题。即使不建实体,只要进入程序,连基准平面,基准点,基准坐标系,都有上述故障。
 楼主| 发表于 2012-12-7 12:21 | 显示全部楼层
显卡问题
HD2000的集显应该可以的。
 楼主| 发表于 2012-12-10 11:10 | 显示全部楼层
确实是集显的问题。
HD2000居然不如我六年前的
AGP8X——GF440
看来即使低端独显也比高端集显强啊。
解决方法,调低分辨率为1024*768,颜色16位,即可流畅运行PROE3.0。
本来的计划被打破了。只好再加个低端独显了,哎!
GMT+8, 2025-11-6 15:01 , Processed in 0.124011 second(s), 23 queries .
